Cracked sub
JimMueller
I have a legacy Velodyne F-1200 sub I bought in probably in 1991. It has recently incurred cracks and a small hole in the soft 'ring' which surrounds the cone. The manual says the cone itself is a resin/fiber material. I can tell that ring is not rubber like what's around the cones in my SDA-1C's.
I left a message for the parts department yesterday but I guess I missed them by a few minutes. Since the sub is so old, is it worthwhile to attempt to buy replacement parts? If not, then I'd like to keep the price <$1000 and have it work well with my Polks. Combination of HT and stereo listening, room is about 15' square.
Thoughts?
Thoughts?
Yamaha RX-2600 receiver, Nakamichi Dragon, Mitsubishi HS-U80 VCR, Pioneer DVL-90 LD Player, Sony BDP-S550 Blu-ray player, Sony CDP-X555ES CD player, Carver TFM-42, Carver AV-634, Panasonic TC-P54V10 plasma, BenQ W1070 PJ, Fisher MT-90 turntable, AKG-K340 headphones, Polk SDA-1C mains, CS-400i center, FX A4 surrounds, Rti A1 surround backs
Post edited by JimMueller on
probably foam, you can replace it for about $50 at a repair shop or DIY and buy a foam kit on-line.
worth keeping and fixing if all you need is to refoam...
NotaSuv
I love this
"I'm not totally useless. I can be used as a bad example" -
You could contact the manufacturer and get it repaired.
If they don't have the replacement driver, try to find out the specifications OF the driver....WHEN it was available. They may or may not provide this data. If they don't, there are ways to figure most of that out, at least enough that you could find a replacement driver on your own.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
just check around for a repair shop that will re-foam it for you. -
This is why I totally loathe foam surrounds. They decay way before their time. While the original surround was foam, would it be OK for him to get it reattached with a rubber surround instead for more durability/longevity?
Squishy Tia wrote: »This is why I totally loathe foam surrounds. They decay way before their time. While the original surround was foam, would it be OK for him to get it reattached with a rubber surround instead for more durability/longevity?
If it came with foam, it's best to stick with foam. Changing the surround material can change the characteristics of the subwoofer.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
If it was a vintage loudspeaker I'd consider the actual woofer characteristics but it's just a subwoofer. If anything it may help tighten the response up.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I would consider replacement w/rubber I think KAWIZX9R is right it may change the driver (probebly tighter) but the driver will change sound with new foam anyway .
And unless the rubber is VERY stiff the change may be very slight , PLUS rubber = no rotting foam problems . -
Just a follow-up that Velodyne has absolutely nothing to give me except schematics, which I asked for. I found a site which offers a fitted foam surround specifically for my model, or one which is a trim-to-fit with rubber. Won't the rubber soften with use like it did with the 1C mid's?Yamaha RX-2600 receiver, Nakamichi Dragon, Mitsubishi HS-U80 VCR, Pioneer DVL-90 LD Player, Sony BDP-S550 Blu-ray player, Sony CDP-X555ES CD player, Carver TFM-42, Carver AV-634, Panasonic TC-P54V10 plasma, BenQ W1070 PJ, Fisher MT-90 turntable, AKG-K340 headphones, Polk SDA-1C mains, CS-400i center, FX A4 surrounds, Rti A1 surround backs
Depends on the composition of the rubber and it's certainly possible but if you can get another decade of use out of it....CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
