I need a cheap car battery.
ben62670
ben62670 Posts: 15,969
edited December 2009 in The Clubhouse
Anything decent in the bottom of the line batteries out there?
Thanks guys.
Ben
Ben
  • Libertyc
    Libertyc Posts: 915
    Walmart!
  • ben62670
    HeHe Somehow those damn batteries died right before the full replacement warranty died:)
    Ben
  • Libertyc
    Libertyc Posts: 915
    Sams club.
  • danger boy
    danger boy Posts: 15,722
    look in this Sunday's news paper ads.. there are usually some batteries on sale... I would say.. Wal Mart, K-Mart, Shucks auto parts, other locally owned car parts places.
    PolkFest 2012, who's going>?
  • TNRabbit
    TNRabbit Posts: 2,168
    The yellow WalMart MAXX batteries are the best deal I've found: 8 year warranty, 3 year FREE REPLACEMENT, only $75.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Fireman32
    Fireman32 Posts: 4,845
    +1 on WalMart or if you belong to Sams or Costco you can get a good deal there as well.
  • NotaSuv
    NotaSuv Posts: 3,871
    I have found long term parking lots at the airport a gold mine for used car parts.........................seriously WalMart or Sams have some good prices, had one go bad from Sams and they replaced it even after 2 1/2 years.............
  • WilliamM2
    WilliamM2 Posts: 4,812
    Last one I bought was at AutoZone. It will be 7 years old in January, still going strong, about $50.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Last one I remember buying was from car quest 550cca 7 year warranty $45 bought in 2002 and still going strong.
  • concealer404
    concealer404 Posts: 7,440
    I think i'm using a lawnmower battery in my car.
  • nadams
    nadams Posts: 5,877
    You don't want a cheap battery, you want a good one. Can't tell you how many of our cheap-o Valucraft batteries were brought back when I worked at Autozone. Usually they just quit working one day... no warning. I'm guessing something internally broke in them. Still, getting left sit when you expect to go out and run to work does not make people happy, even if the battery is under warranty.
    Now, my Duralast Gold on the other hand, 3yr free repl, 7 yr pro-rated... and it's on it's 2nd year and still cranking fine. I think I paid close to $90 for it, tho.
    Ludicrous gibs!
  • Systems
    Systems Posts: 14,872
    A junkyard. You can actually find new batteries there at a fraction of the cost to a new. Go find it yourself. I located a 650cca Interstate that tested new and looked new for only $15. And I went there to get a pair of A pillars for an audio install in my truck (tweeters) when I saw this battery I thought would work in my Honda run-around-town ride.
    Testing
    Testing
    Testing
  • shawn474
    shawn474 Posts: 3,052
    nadams wrote: »
    +1 on the duralast gold.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I'll be the fourth to recommend the Duralast batteries by Autozone, hard to beat
  • Jstas
    Jstas Posts: 15,014
    The Duralast from AutoZone. They are made by Exide or Interstate for Autozone last I checked and they are usually less than $70.
    Pep Boys also has perpetual sales on batteries and their ProStart line is Exide or Interstate as well, equally cheap and they offer a favorable core return. When a battery is on sale at Pep Boys, I have been able to pick one up as cheap as $45 after the core was returned.
    Expert Moron Extraordinaire
  • thsmith
    thsmith Posts: 6,082
    AUtozone's battery was rated best buy by consumerreports.
  • crogers227
    crogers227 Posts: 26
    I live in AZ where people burn through batteries and the Duralast has always done very well for me. Go with it and you wont go wrong
    A/V Receiver...........Denon 1910
    Power Conditioner....MP HD IR 2550
    BluRay Player..........Sony PS3
    Fronts....................RTi 100
    Center...................CSi3
    Surrounds...............FXi3
    Sub.......................Micropro 3000 :D
    Extras....................Harmony One, Xbox 360, Wii
  • xj4094dg
    xj4094dg Posts: 1,158
    187CAM wrote: »
    + 1. This is the cheapest way to go. Alot of the newer cars are going to salvage because they aren't worth much after minor to medium accidents and the insurance companies are totalling them. You can score a good battery for cheap. I even found a very fresh set of Pirelli tires for $10.00 each once.
    Check it out Ben!
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • Serendipity
    Serendipity Posts: 6,975
    DieHard has worked well for me.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • thsmith
    crogers227 wrote: »
    Those are the one Comsumerreports rated best buy.
