amps
hello everyone I am new to the forum. Just got lsi 25s looking for a good amp to drive them there 4 ohms 20 to 300 wpc. Can you use a 300 wpc amp. Am a fan of carvers but am looking for suggestions Thanks
Post edited by 27wsc on
Carver TFM-45 or a Sunfire Stereo 300x2 would be nice fits if you want to go Carver. There are others that would be good fits, such as Rotel and Adcom.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
You can use almost any amp you want with no issues. (provided it is stable into a 4 ohm load)Mains.............Polk LSi15 (Cherry)
The more power the merrier
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
There are many amps that will drive your 25's. I have not had receivers for some time, but separates, many will do the job. What is your price range, you could find many in the used market and great for your application. By the way, do not listen to those that state more wattage is better. Watts are Watts, but not all watts are the same. Do not pay attention to those that has nothing to contribute to your question as such. 300 watts, yes you can use it, there are thousands of companies that claim such numbers, but not all of them can perform.
Many people will advise you to buy used. If you prefer new and don't want to spend a fortune you might consider this
http://www.audioadvisor.com/prodinfo.asp?number=2PAC5250
Of course, you may not need five channels.MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
If you want to buy a new, 2 channel amp, and you're willing to go as high as $1500, you might try one of these:
http://www.wyred4sound.com/webapps/site/74030/117839/shopping/shopping-view.html?pid=332077&b_id=&find_groupid=18047
500 wpc into 4 ohms---sounds sweet (after break in). The drawback, apart from having to pay for it, is that not all speakers sound sweet with class D amps (LSis do), so your speaker upgrade options in the future will be a bit limited. Big advantage, you can carry it with one arm. And maybe you won't want to upgrade. -
Adcom 565 mono amps . . . 300 wpc. You can them pretty cheap on ebay or audiogon. -
Are you going 2 channel with the Lsi25's or beginning to create a HT? Certain amps sound better with certain speakers, trust me. I have used a Luxman M-117 amp and Carver amps with my Lsi 25's and both sounded excellent. If I run my old SAE amp, not so good for some reason but the SAE amp sounds great with my old Monitor speakers. Really,all of the gear is going to affect your sound, such as the pre amp, speakers wires and acoustics of your room. The amp is a building block. A quaility amp that can pust out at least 200 watts stable into 4 ohms would be a good start.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
hearingimpared wrote: »Adcom 565 mono amps . . . 300 wpc. You can them pretty cheap on ebay or audiogon.
Adcom makes some pretty solid stuff - they get my vote as well!Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
I dont own the LSI 25's but i am learning a quite a bit just reading all of your posts.A/V Receiver...........Denon 1910
Power Conditioner....MP HD IR 2550
BluRay Player..........Sony PS3
Fronts....................RTi 100
Center...................CSi3
Surrounds...............FXi3
Sub.......................Micropro 3000
Extras....................Harmony One, Xbox 360, Wii -
I know i'm gonna catch some flack but here goes! If you'd like to get new amp's with warranty at reasonable price's check out the Emotiva stuff, they're having a pretty good sale that's on 'till the end of the month. IMHO you get quite a bit of performance for your $$$
I also seen a trio of low hour (approx 20hrs) xpa1's on agon earlier today for like $650 or so each, they come with a 5yr warranty that is transferrable so you'd be covered
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
