LS's (Bi-amping or external amp)?
bilal
bilal Posts: 8
edited December 2009 in Speakers
Hi,
I'm new to this forum, and after reading some of the replies on the thread I decided it may be a good idea to post my question here. I do want to say that I'm not to savvy as far as electronics are concerned.
So here is my situation. I recently upgraded to LSi15's after thinking about them for a long time (12 months to be exact). Here is my current setup
Amp: HK AVR 247, (http://manuals.harman.com/HK/Owner%2...om%20lores.pdf)
speakers: Pair of LSi15's
Sub: Cambridge P300HD
When I plugged these in, I didnt get the output that i was looking for. The manual has the following configuration for this amp:
50 Watts x 7, seven channels driven at full power at 8 ohms,
20Hz – 20kHz, <0.07% THD (surround modes), 350 watts total
• 65 Watts x 2, two channels driven at full power at 8 ohms,
20Hz – 20kHz, <0.07% THD (surround off mode), 130 watts total
While reading other posts, I discovered that I could use the multiroom/SB (Remote Speakers) option on the amp for lower frequencies for my LSi's.(i think its called bi-wiring or bi-amping) Is this a safe option, some people have suggested that if you under power your speakers you could damage them and the amp?
There also has a connection for a pre-amp at the back. While this is something I could invest in, I cant look at spending more $200 max at this point.
do you think I should power the speakers with the bi-wiring option? or is that a big no no.
Post edited by bilal on
  • kawizx9r
    kawizx9r Posts: 5,150
    External amp.
    Your receiver is not meant to play 4ohm speakers. If you turn it up to high-levels, you'll risk damaging both your receiver and speakers.
    An external amp will almost always be a step up from a receivers amp section (unless you've got a high-end receiver), but to really make those LSi's shine you'll need to spend a good amount of coin for a high-current amp. Also keep in mind, your speakers (or any for that matter) are way more prone to being damaged from being underpowered as opposed to overpowered.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Serendipity
    Serendipity Posts: 6,975
    kawizx9r wrote: »
    +1
    Most receivers will go into protect mode if the load is too great or the unit is clipping.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • cfrizz
    cfrizz Posts: 13,415
    Get a separate amplifier of at least 200wpc @ 8ohms. The more power you can give them the better they will sound. Don't bother with bi-amping.
    Amps to look at are Parasound, Outlaw, Emotiva, Sunfire, B & K, Nad, Adcom, Rotel.
  • bilal
    bilal Posts: 8
    guys, thanks for all the responses,
    Im am stuck between a NAD( 2600A)and an ADCOM GFA-555.
    Here some of the specs listed on both
    NAD:
    Continuous power [ min RMS per channel 20Hz - 20kHz less than rated distortion into 8 ohms ]:
    -::- 150W RMS x 2
    -::- Rated distortion [ THD, 20Hz - 20kHz ] 0.03%
    -::- Clipping Power 200W : Dynamic headroom +4dB
    -::- IHF Dynamic Power x 2 at 8 ohms: 400W 4 ohms 600W 2ohms 800W;
    -::- RIAA response accuracy : 0.5dB
    -::- Damping Factor [8 ohms, 50Hz]: > 120
    -::- Slew Factor > 50 -::- Slew Rate > 35V / sec
    -::- Input impedance R = 20kohms, C = 820 pF
    -::- Input sensitivity [ 1W out / rated power ]: 90mV / 1.1V -::- Voltage gain 32 x [ 30dB ]
    -::- Signal to Noise Ratio [ 1W / 150W, A-weighted ]: 100 / 122dB
    Bridged Monophonic MODE :
    Continuous power [ min RMS per channel 20Hz - 20kHz less than rated distortion ]:
    -::- 8 ohms 1200W RMS
    -::- 4 ohms 1600W : Dynamic headroom +5dB
    AND ADCOM
    # Output Power: 200W into 8 ohms (23dBW);
    # 325W into 4 ohms (22.1dBW),
    # all continuous power, 20Hz-20kHz, with 0.09% THD.
    # Input impedance: 22k ohms.
    # Sensitivity: 130mV.
    which one would you think would be better with the LSi15's and how much do you think is a reasonable price for either one... Thanks much
  • kawizx9r
    I'd say the 555, can be had for about $300 unless its the MKII which is often a lil more like $350.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • bilal
    bilal Posts: 8
    thanks, I just posted a question to the seller asking him if its MKII or not.
  • bilal
    bilal Posts: 8
    guys one last question, I am also considering getting my hands on a B&K ST-202+... Does anyone know how this amp sounds? Is it any better than ADCOM 555 or 5500? I would think the price range would be the same for both.
  • bilal
    bilal Posts: 8
    also the seller got back and said the 555 is not an MKII version.
  • kawizx9r
    Can't say anything about the B&K, but as far as the 555 goes offer him $285. You can go a little higher but hey, we're all trying to save an honest buck here aren't we? :)
    -Freddy
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • dorokusai
    dorokusai Posts: 25,576
    The B&K ST-202 is a wonderful amplifier. I'd say it sounds better than the Adcom and is nicely built.
  • bilal
    bilal Posts: 8
    guys there is a GFA 7500 5 channel amp on ebay. My question is can the amp power my front speakers and my sub woofer. or do i need to get a different amp for that.
    the output options at the back of the GFA 7500 are:
    Front R:
    Front L:
    Center:
    Surround R:
    Surround L:
    can the woofer be plugged into remaining slots besides the Front ones. If so I will go after this, if not I will purchase just the two channel one.
    Thanks.
    I would be carefull buying anything from e-bay, the B&K option seems to be the good one for now. If your sub,as most do,has it's own amplifier built in,then no need for an external one. If not,and it's a passive sub,then you would look for a monoblock amp for it,not run it off a 5 channel amp. You could do it but results may not be up to snuff. Keep the volume down on those speakers untill you get an amp,that receiver is nowhere near what is needed to power them. DON'T forget the cables to hook up your amp too.
