Drive Backup Software?
pitterson
pitterson Posts: 3
edited December 2009 in Electronics
I'm looking for some sort of hard drive backup or imaging software that I can use in the following way:
Plug in an external DVD 16x USB burner then Boot to a CD on the PC. The software would load, and I could backup the hard drive to the DVD burner - maybe several media used.
Later I could plug in the external USB DVD burner, boot to the CD again and restore all the data from the DVD to the hard drive.
Does such software exist? I don't want to install anything to the OS.
Post edited by pitterson on
  • Sherardp
    Sherardp Posts: 8,038
    I would suggest Norton Ghost.
  • janmike
    janmike Posts: 6,146
    All over the map as well.
    Michael ;)
    NORTH of 60°
  • Gadabout
    Gadabout Posts: 1,072
    Never been a fan of the ghost, for imaging and back up I have always used Acronis True Image.
    A friend of mine turned me on to it a few years back as it was the only software that would do a back up and restore over a RAID. Also, for most of the plants that I visit it seems the IT guys are using this in the labs for all the computers that are there.
    Hope that helps,
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
    heiney9 Posts: 25,497
    Gadabout wrote: »
    Hope that helps,
    Scott
    This is what I use and would recommend.
  • Face
    Face Posts: 14,340
    How about Win7's backup?
  • tcrossma
    tcrossma Posts: 1,301
    I use Ghost 14 and am quite pleased. Ghost has had some good and some bad releases over the years, but this one is good.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Serendipity
    Serendipity Posts: 6,975
    I've only used Ghost before and it works.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • polktiger
    polktiger Posts: 556
    I have been considering trying Acronis. Probably should have gotten it when is was BF special at newegg. But I have been using Cobain Backup for regular back-ups not actual drive imaging.
  • nguyendot
    nguyendot Posts: 3,594
    Symantec Backup Exec :)
    Main Surround -
  • Gadabout
    tcrossma wrote: »
    I probably had one of the first versions of ghost. It drove me crazy as it always kept the HD spinning doing something in the background. Would also cause some lag when I was gaming too. Sounds like they got it figured out.
    I don't have the newest version of Acronis, but the backups are done as an intial image, and then increments are added to it. I've had to use the backup once and it worked flawlessly.
    Scott
