Streaming HD from computer
Willow
Willow Posts: 11,231
edited December 2009 in The Clubhouse
The Thread that Madmax started about how much he was spending/then going to save got me thinking. I'd like to ditch cable/tv as we only watch a couple shows, no news no sports. Most of the shows we watch are available on line through the TV channels. My question is, how can I stream HD from my pc to my tv by using my ps3? is this at all possible? right now I use the google ps3 media server I can stream non HD. Could I just watch the HD content by using the browser in my ps3?
Does this make any sense?
Post edited by Willow on
  • vc69
    vc69 Posts: 2,500
    Not familiar with how to do it with a PS3 but I can say that HD streamed over the net is gawd awful PQ wise.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Willow
    hmmm not good then
  • MrGlobe
    MrGlobe Posts: 401
    I want to do the same thing willow, However I do not care about PQ. If it looks like crap that is fine, however I want it to sound good!
    heiney9 Posts: 25,432
    Netflix and Roku player
  • Willow
    heiney9 wrote: »
    Do I need an HD video card? and what do you mean with the above? sign up for netflix and stream TV shows? but I need the Roku player? right?
    Yeah, are you looking to stream current run shows rather than subscribing to cable? Right now Hulu allows that but I can tell you with all the popularity of streaming shows it will no longer be free next year. Also a site like Hulu doesn't stream in high enough quality to use a regular TV. It's more like a You Tube video box.
    No HD card needed for Roku just a wireless network. If your connection is fast enough you can stream in HD.
    http://www.roku.com/roku-products
    The cost is one time for the player and $8.99/M to Netflix.
    I know of no way to stream current TV shows in HD for free. If you could do that why would anyone pay for cable? I'm not aware of a way to stream even regular resolution current TV full screen for free.
    All the palces that stream current TV shows are for the computer and the video boxes are set up like You tube..........small and poorer quality.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Willow wrote: »
    If you sign up with Netflix, you can request the disk that allows you to stream through your PS3, no other box required. It took about 2 days to get my disk after I requested it. HD streams are not quite Bluray quality, but look pretty darn good.
    edit: here's a link.
    http://www.netflix.com/ps3
  • Willow
    heiney9 wrote: »
    My PS3 is hardwired to the router and we are curently running 10MBS and thinking of going to 25mbs connection. 8.99 is that unlimited?
    heiney9 wrote: »
    I guess legally you can't. I know some shows are in hd but in torrents.
    Thank you I will look into this, thanks!
    ^^ Yes, if you have a PS3 you're half way there as far as using Netflix selections. I missed that part of your original post.
    $8.99 is unlimited, plus you still get your (1) DVD selection, obviously if you're on a higher plan then you'd get that many DVD's out at one time, etc.
    billbillw Posts: 7,538
    Are the shows you watch broadcast over the air? If so, you might think about putting up an antenna. There are some inexpensive HD tuners than can be fitted to a computer and come with DVR software that will allow you to record/playback. If you did that, you would have pristine HD quality playback.
    I am doing something similar, but I went and spent a few bucks for a Series3 TivoHD. Only $10/month and I can record two channels and stream Netflix. I got rid of DirecTV to do this and so far, I don't miss the satellite service (and it saves me about $70/month.)
  • thsmith
    thsmith Posts: 6,082
    +1 if you can get the channels
  • Ricardo
    Ricardo Posts: 10,636
    Edit.
    That was too late. Off the air HD already mentioned.
    SOPA
  • Willow
    We usually watch the big network shows....ie, House, Grey's, Dexter and so on.
    So maybe the indoor might work....thanks If we do this we'd save over 80 a month.:eek:
  • Ricardo
    This is what I used to locate the TV stations in the area and decide where to mount/point my antenna:
    http://www.antennaweb.org/aw/Address.aspx
    enter just the zip code, then you'll get a map where you can select your exact location.
    Edit: sorry, only for U.S. There must be something similar for Canada.
    SOPA
    Willow wrote: »
    I'd invest in a proper outdoor antenna if you want reliability. I've had one up for more than 5 years and I swear by it. You can count on it like Old Faithful. Wind, rain, thunderstorms, snow, leaves, etc. Nothing stops me from getting a solid signal short of the local network having an outage, which really never happens unless a helicopter crashes into the radio tower!
  • Willow
    no netflix in canada :mad:
    Willow wrote: »
    Looks like Zip is your equivalent. Not sure if zip has streaming yet or if any CE devices support it.
  • Willow
    billbillw wrote: »
    Not that I can tell. I'll put on my sherlock cap when I get home
    Willow wrote: »
    Seems like they announced they were bringing it back in June, supposed to happen in the fall. Not sure if it fell through or was delayed. Some type of partnership with Sonic Cinema Now. Good luck Mr. Holmes!
  • Fongolio
    Fongolio Posts: 3,516
    There is a great program for streaming from PC to PS3 called PS3 Media Server. It's free and it can stream HD content. I have successfully watched several Blu ray quality movies and listen to a fair amount of my ripped cd collection streamed to PS3. I don't know if it can do live streamed internet content though. Another cool feature of the music server end of the PS3 is I can stream music to the PS3 and output it through the optical out in my DAC and have very high quality music on the two channel rig.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • unc2701
    unc2701 Posts: 3,587
    Check out playOn:
    http://www.playon.tv/playon/
    Not HD, but lets you watch Hulu (and many other services) on your TV with the PS3 interface.
    Backburner:Krell KAV-300i
