Harman Kardon HK-3390
sk1939
sk1939 Posts: 295
edited December 2009 in Electronics
Yes? No? Is it a good receiver? Thinking about requesting it as a gift for the holiday season. Is it a good receiver? Any other suggestions? I'm thinking about replacing my Sony (old, heavy, sound quality is good) with something with more power/more modern (and has a remote).
I'm really not looking to spend more than $250 incl. shipping if possible...I like the fact that it has both sub and preouts....
Home:
Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
Home 2 (Playback):
Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
College:
JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII
Post edited by sk1939 on
  • coolsax
    coolsax Posts: 1,826
    HK is a pretty good product.. you might want to look at the 3480 and 3485 refurbished if you can.. those have a little more power..
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • sk1939
    sk1939 Posts: 295
    coolsax wrote: »
    Aren't those older models?....remember that I'm only powering 2 TSi 100's...hardly a demanding load. so I think 80W is sufficient (am I wrong?)...
    EDIT: It looks like they do have a sub out, but refurbished they are more expensive...
    Home:
    Home 2 (Playback):
    College:
  • coolsax
    yes if its just two Tsi100's the 80 watts should be plenty
    Main 2ch -
    TV 3.1 system -
  • sk1939
    sk1939 Posts: 295
    Ok, so here's a question....my equipment is listed under my first post....should I get a pair of Monitor 60's instead? Or go for the receiver?.....both are about the same cost.
    Home:
    Home 2 (Playback):
    College:
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I'd look at upgrading the receiver. The HK 2 channel receivers are way underrated, they're VERY good receivers. I traded out my integrated amp for the 3480 for convenience, and ended up with an upgrade in sound quality.
    I have an extra 3480 in storage that I'm not using, have 2 in use right now. I may be willing to part with it if you happen to be local, but don't really wanna mess with shipping it, plus I'd want you to be able to listen to it before buying it anyway - where are you located?
  • sk1939
    sk1939 Posts: 295
    North Central PA
    Home:
    Home 2 (Playback):
    College:
  • AsSiMiLaTeD
    Ah, well I'm in the DFW area, but if I were you I'd be on the lookout for a 3480 or the newer version of that. It's only a little more power, but it's a better receiver all around IMO.
  • sk1939
    sk1939 Posts: 295
    Is it that much better? Whats the difference?
    Home:
    Home 2 (Playback):
    College:
  • AsSiMiLaTeD
    I don't know all the technical differences, but I tried them both at first and the 33xx series just didn't have the oomph that the 34xx had for me
  • sk1939
    sk1939 Posts: 295
    Hmm....I'll consider it, but I think that the 34xx is out of my price range, and again, 80W should be enough oompf for some TSi 100's......you think the receiver would be a better upgrade than the speakers?
    Home:
    Home 2 (Playback):
    College:
  • domflane
    domflane Posts: 653
    Upgrade the receiver first. The Tsi100's will wake up a little when you put the Harman on them and then down the road you can opt for bigger speakers. If your only concern is 2 ch then you should think about going vintage, you can find an older pair of monitors or the older RT series for pretty cheap on CL. Whats nice about the HK is that it gives you the option to add an amp in the future. Good luck with your upgrade . . .
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • AsSiMiLaTeD
    grabbing the 34xx over the 33xx will also give you more options for upgrading your speakers down the road, the extra juice in the 34xx will make driving a heavy 4 ohm load like the LSi series a more realixtic option.
    There's a 3480 on ebay right now for a BIN price of 119, I'd take that over the 3390 on HKs website for $245 any day.
  • Conradicles
    Conradicles Posts: 6,375
    In the past I have owned both the 3480 and 3490 and loved them. Great budget stereo receivers.
    I like the fact the displays can be turned off as well.
    Nice warm detailed sound.
  • sk1939
    sk1939 Posts: 295
    Is the 3480/90 able to drive a load like an LSi well? I'll see about getting it....I'm always leary about buying used equipment, especially off ebay....
    Home:
    Home 2 (Playback):
    College:
  • Conradicles
    It will push LSi's fine.
    Look at AsSimiLaTed's gear....he's driving LSIs with that AVR...and a number of others are driving even larger LSIs and SDAs with the same!]
    cnh
  • RyanJoz
    RyanJoz Posts: 116
    I drove RTiA9's with a 3370 for a while until i got the upgrade bug. The big difference I notice with the Adcom GFA 5503 amp is bass response. With the HK receiver the bass was there, but never this noticeable. I turn the sub off for music and only have it on slightly for HT. The receiver will do a good job until you get the urge to do some serious upgrading.
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
  • cdn5003
    cdn5003 Posts: 144
    I have the 3490 powering Rti A3s. It powers them easily and has plenty of headroom. I believe that the 80 watt HK would be plenty of power for your Tsi series speakers. There might not be any difference between the two when driving efficient speakers. The build quality of HK stereo receivers is excellent. They are built like tanks. The sub out is a great feature both of them have.
    My vote would be to get the 3390 unless you plan on getting less efficient speakers or need optical/coaxial connections. You can always add a power amp to the 3390 and use it as a preamp. Both are great choices though.
    HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
    2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
