Pioneer SC 05
hoosier21
hoosier21 Posts: 4,437
Pretty damn pissed, spent the weekend cutting holes and runing cable for the inwall speakers, Plasma TV and Pioneer receiver I have had for nearly a year, get it all hooked up and nothing from the subwoofer. I have two subwoofers, tried them both, 3 different cables.
Going trough the set up, it is set for subwoofer YES, running the test tones, silence when it comes to the subwoofer.
Dead subwoofer out on this receiver is all I can think of, anybody got an idea what I might be missing?
Thanks in advance.
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
  • speakergeek
    speakergeek Posts: 555
    edited December 2009
    It does sound as if you have a bad sub out...
  • leroyjr1
    leroyjr1 Posts: 8,785
    hoosier21 wrote: »
    Thanks in advance.
    Russ
    Try running the subwoofer on plus instead of yes.
  • hoosier21
    leroyjr1 wrote: »
    just tried that, still nothing, :mad:
  • dorokusai
    dorokusai Posts: 25,661
    Have you tried testing the subwoofer on a full range, Large, pre-output?
  • leroyjr1
    hoosier21 wrote: »
    Did you try plugging the sub cable into a different output like the center of front outputs just to rule out it being a sub and cable problem. Going thru my menu to see if I can find a setting you might be over looking.
    Did you run MCACC?
  • leroyjr1
    OK, try this. There's a Audio Parameter button on your remote. Stroll thru there and make sure the LFE setting isn't set to off.
    Just a thought.
  • hoosier21
    thanks, I will try more tomorrow, can't do anymore tonight
  • dorokusai
    It's just white noise.
  • hoosier21
    dorokusai wrote: »
    kids in bed, bedrooms on each side of the livingroom where this crap is.
  • dorokusai
    I've found that young people recover quickly from being disturbed by gunshots, smoke inhalation and naked women in the backyard....what's the difference?
  • BlueFox
    BlueFox Posts: 15,250
    Set sub to NO, and run it off the front pre-amp out.
  • leroyjr1
    BlueFox wrote: »
    That would work but what's the point of having a feature if it doesn't work. He needs to solve that issue first.
  • dorokusai
    It's just troubleshooting Leroy.
  • hoosier21
    ok, I need glasses and my 14 year old needs to help me read better. we had the interconnect plugged into the multi channel input for the subwoofer. Basic 101 error.
    better light and a few less beers and I got it all squeared away.
    Thanks for the help.
    Russ
  • leroyjr1
    hoosier21 wrote: »
    Russ
    Lol
    was going to mention that but figured you was a veteran.:p
  • hoosier21
    leroyjr1 wrote: »
    Lol
    me too simple things are the hardest :rolleyes:
    Tony M Posts: 12,029
    Man is that a familiar solution to alot of my problems from the past and I WILL use it again.
    Walk away....calm down...sleep on it...go back and find out reason.:D
    I'm glad you figured out the reason it wasn't working.
