Receiver shutoff problem
recif
recif Posts: 3
edited December 2009 in Electronics
I hope I am posting this in the right forum. If not please let me know.
I have Polk LSi15 front speakers and a Polk LsiC center speaker connected through an Emotiva XPA-3 amplifier to a Pioneer Elite SC-05 receiver. When I try to play a SACD on a Yamaha S1800 connected to the multichannel analog inputs on the Pioneer, after a minute or so the receiver switches to muting and if I turn off muting the receiver shuts off. This happens even at low sound levels. Does this indicate a problem with the receiver or the connections?
Thanks for any help.
Post edited by recif on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    are any wires on the receiver touching each other or stray strands of wire sticking out?
  • recif
    recif Posts: 3
    No wires seem to be shorted.
    I can play SACD or BD on a PS3 connected using HDMI.
  • vc69
    vc69 Posts: 2,500
    I would definitely re-check all speaker connections. Also, and where I would start, is swapping the IC's connecting the player to the AVR. They could be bad.
    Is the SACD player the only source causing this problem?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • recif
    recif Posts: 3
    I switched out the ICs from the SACD player to the receiver and that seems to have fixed the problem. Thanks for the help.
