Common Ground Amp?
Driver_King
Driver_King Posts: 266
edited December 2009 in Vintage Speakers
I have a Technics SU-7300 stereo amplifier and was thinking about connecting it to my SDA II's, while my 805 acts as the pre/pro. I was about to disconnected the subwoofer in the living room from the amp when I saw a knob on the back of the amp. Above it, text is there that says "ground". Right above the knob, it says Left/Right. Does that mean the amp is not a common ground amp?:confused: I just want to be sure that if I try this, I don't end up exploding my SDA's.:eek:
Home Theater:
Onkyo TX-SR805
Behringer EP2500 for SDA's
Polk SDA II fronts
Polk Monitor 5Jr. surrounds
Polk Monitor 4 back surrounds
DIY A7-900 and DIY A3-300
Post edited by Driver_King on
  • ben62670
    ben62670 Posts: 15,969
    Take an ohm reading across the negative speaker ground. AFAIK the ground switch only "lifts the ground kinda like a cheater Plug.
    Ben
  • Driver_King
    Nevermind. I just realized it said GND, not ground, and it is right next to the Phono input. duh.gif:o:D I'll be hooking up the amp in a bit and will post the results later.:)
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • Driver_King
    :eek:
    And I've had this amp all this time!!!!:mad::D
    I'm making room on my armouir.:p The PS3 is going vertical in the middle.:cool: I'm thinking a 2' BJC stereo cable for the connection (I only have a Monoprice Premium cable connected for now). Will that make a nice difference? Any other suggestions?:)
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
    F1nut Posts: 51,997
    One and the same, but you're right, it is for the TT.
  • hearingimpared
    hearingimpared Posts: 21,136
    +1 one on that.
  • Driver_King
    Oh yeah, I understand, it's just that as soon as I saw it said GND, not ground, that reminded me it was for the Phono input next to it:D
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
