CS400i and 2 additional centers
I plan on adding 2 more center speakers off the receiver center pre-out( thru additional power amp, of course) as soon as I can decide what would be a good match for my current CS400i center. I was thinking either a pair of CSi20's or possibly RTi28 or 38's. I would like to get some feedback from others using this arrangement!
JVC AV48WP30 Widescreen TV
Marantz SR6200 Receiver
Panasonic RP-82 DVD
Sony SAT-A50 DSS DD Receiver
Sonic Frontiers Anthem Amp 1
Tara Labs-Axiom Interconnects
Tara Labs Digital 75 Co-axial
Kinima HiG2 Mains
Polk CS400i Main Center
Kinima KC2 Rear Center
Polk FX300i Rears
Polk PSW 350 LFE Sub
M&K V-3B Mains Sub
M&K V-2B Mains Sub
M&K LP-1S High Pass Filter
Ultralink Bi-wiring Thru
AR Pro Series Interconnects
Marantz RC2000 MKii Remote
Panasonic RP-82 DVD
Kinima HiG2 Mains
Polk FX300i Rears
M&K V-3B Mains Sub
M&K V-2B Mains Sub
Post edited by weiser on
Check out my HT - been there done that. Rt35's perfect matches.
So has Todd (tvtnt). Works great. But I will be moving speakers around soon. 7 channels on the way. Go with the 38's if you can't find 35's.
Also many recievers won't use internal power once you use the preouts. But my Onkyo works flawlessly.
Do a search on ****center on steriods****!!!!!
Need more info let me know. -
I just added 2 more subwoofers to the center and rear off pre-outs and seems to be working fine! On a side note, for the center sub I used a y-spitter from the center pre-out to the l/r line-in on subwoofer in order to sum the response. I assume this is better than just running to either the left or right input? I decided to go with the 38's because of the promo and the free subwoofer. Now I just have to locate a power amp and I will be off and running! What a huge difference for dvd-audio and movies like U-571! The only question I have is how to wire the power amp into this equation. I figure I will run a splitter off the center preout to the sub and to the amp( splitting again at the amp inputs) in order to add the 2 extra speakers. I avoid using the speaker line level inputs this way! What do you think?JVC AV48WP30 Widescreen TV
Panasonic RP-82 DVD
Kinima HiG2 Mains
Polk FX300i Rears
M&K V-3B Mains Sub
M&K V-2B Mains Sub
Marantz RC2000 MKii Remote -
It should work fine that way - give it a shot and let us know how it sounds.
