Question about bi-amping the RTi-A9's.
cbruinooge
cbruinooge Posts: 11
I know that the bottom posts are for the three 7" bass drivers. What I am not sure about is the the top posts. I know they go to the tweeter, but I am wondering if they go to the 5 ¼" mid range drivers as well. I am going to be sending 80 watts to each set of posts, and I think that 80 watts seems fine for the 7's, and maybe to much for just the one tweeter. However if the top posts do power the 5 ¼" mid range drivers and the tweeter I think it could sound great. Just looking for some conformation on the wiring set up. Thanks everyone.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited December 2009
    I do not own a set so i can not answer if it powers just the tweeter or the tweeter and the mids but regardless 80 watts is NOT too much. At 80 watts you'd be more than fine even if you had 80 watts for each driver itself.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • quadzilla
    quadzilla Posts: 1,543
    I'm running RTi12s, the previous version of the A9, and put 425 watts into each post, so I'm pretty sure you'll be OK with 80.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • CoolJazz
    CoolJazz Posts: 573
    Welcome to the forum! Hang around for a while.
    The power involved to drive a bass unit normally is WAY more power than the tweeters use. So with a normal sounding drive balance, you'll be putting a LOT more power to the bass side.
    If your using a multi-channel amp, set the gain to each section the same for starters, which you probably won't want to adjust much if any, and the actual power you'll be applying will be fine for the tweeters.
    Remember that 80 watts isn't a ton so don't try to run to the max. You can damage quicker with under power than with over power.
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • leroyjr1
    leroyjr1 Posts: 8,785
    cbruinooge wrote: »
    The top posts run the one tweeter and dual 5 1/4 drivers. 80 watts is not too much, actually you might want to add a little more power.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    More power is almost always better, especially on a set like the a9's ;) 80w is nothing for them. I noticed a very BIG improvement when i switched from AVR power to separate power, my AVR is no slouch but the a9's LOVE the juice :D
    I'm looking forward to bi-wiring mine with some mono block's that are on their way to me :D
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • chargerman426
    chargerman426 Posts: 419
    I have the RTi12's for my HT and I have to say that when I changed from even a high power AVR to some 350 watt carver's i noticed a big change. I even bi-amped with 2 M1.5ts (350 watts x 2) and did notice crisper highs. But if you want an all in one amp like how I decided to go after the carvers. You cant go wrong with the new Sunfire gear. I have a 400x7 Sunfire amp and it sounds great.
    If life had more tubes it would be a lot smoother.
