VM10 or VM20 as side/rear speakers?
ivanejackson
ivanejackson Posts: 7
edited December 2009 in Speakers
I've finished assembling my speakers now, 2 x VM30, 3 x VM20, 2 x VM10 & 1 x micropro 3000 sub. The two VM30s and one VM20 will be my front speakers but I'm unsure about where to place the remaining speakers. Should the VM10s be the side surrounds and the VM20s be the rear surrounds or vice versa? I do have a set of FS10 and FS20 floor stands as well. I can either mount these speakers high on the appropriate walls (angled toward the listening position) or on floor stands. Lastly, the Dolby site says not to put the sub in a corner which is against what I always thought. Any thoughts about what would be best? Thanks (as always) for any insight you have!
Post edited by ivanejackson on
  • blockatvalpo
    blockatvalpo Posts: 87
    I'd put the VM20's as your side surrounds and the VM10's as your rear surrounds. My only reasoning is, 5.1 uses the side surrounds and not the rear surrounds. They'll be used more on the sides than the rear unless you have your receive convert the 5.1 signal into 7.1.
  • jimsvm
    jimsvm Posts: 307
    alittle off topic but what are powering the vms,if you don't mind me asking.
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • ivanejackson
    a Denon avr-790
