Is it OK to lay bookshelves on their side?
edited December 2009 in Speakers
The title says it all...I think I am going to need to lay them down on their side. Will it impact their performance at all?
On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Rears: Polk RC85i (in-ceiling)
Sub: Polk PSW110
Receiver: Onkyo TX-SR607
Patio: Polk Atrium 45
Accessories: Onkyo UP-HTI HD Radio Receiver, SIRIUS SUPH1 Home Kit, Onkyo UP-A1 I-Pod Dock
Post edited by seadoons on
Welcome!
    No, all the sound will leak out! It's like laying a fridge on its side!
    Nope, its not a problem as long as you tilt your head the same way
    Um, thanks? :D I take it the answer is not to worry about it? I want to make sure I have all of my bases covered prior to dropping this kind of money on a system.
    Do the RTI A Series taper in from front to back? That might be interesting laying them on their sides if they aren't perfectly square...
    Fronts: Polk RTi4
    Center: Polk CSi3
    Sub: Polk PSW110
    The orientation of your head has nothing to do with it. The only potential problem is that most speakers are designed to shoot out sound to the left and right (not so much up and down). So, if you put them on the side and you are not in the sweet spot it should be more noticeable than usual. Still, It seems like a number of folks around here us LSi9s on their side for center channel duty. Give it a shot --- it cant hurt.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
    MrGlobe wrote: »
    lmao!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    seadoons wrote: »
    RTi A have rounded and tapered sides, so laying them might be VERY interesting. If you are still stuffing them into the entertainment center, RTi A's unique shape may actually help you aim speakers at the ear level.
    Put the speaker on report ba.
    Put the tweeter on th outside. This is the do mr diffeenact.
    Brn
    Ben
    Ben walk away from the computer, and slow down on the meds.
    hahaha
    It will affect their dispersion.
    If you have no choice but to lay them on their sides, try with the tweeters in and also with them out, see what sound better to you.
    what do you mean by tweeters in and tweeters out?
    The only problem I can see, is getting the books to stay on the shelf. With the shelf laying on it's side, you're basically going to have to stack the books up.
    err...wait...are we talking about speakers?:p
    he means try it with either both tweeters on the inside of the driver while on its side or try it with the tweeters on the outside of the driver ie
    o = tweeter
    O = driver
    Oo Center oO or oO Center Oo
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
    ok i understand, at first i thought he was saying try it with tweeters normal, and then poke them in and try it that way... :-o
    must be a record for humorous responses though
    lanion wrote: »
    Hmm...how about an RTi6 put on its side as a center channel?
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    mystik610 wrote: »
    I wouldn't.
    No offense, but if you have the speaker, why ask the question if you can try it so easily? You are the most important factor in your audio system. If you enjoy it, it is fine!
    HT:
    He doesn't have them, this is a thread about which ones he should get, and the space where he needs them to be is in an entertainment center
    IF the speaker is right in front of you it should not make a difference. If you have lots of seating around the periphery of the sweet spot it might.
    You don't have any local dealers that will let you borrow an Rti6 (or the current incarnation.)
    HT:
    lanion wrote: »
    I wish I had local dealers that did this kind of thing
    =^^^ yeah, my local dealer wouldn't let me borrow his Krell Evolution One's... ridiculous
    LOL sounds like the wrong dealer if you are after an Rti6 sideways.
    HT:
    seadoons wrote: »
    You'll probably experience some imaging problems but nothing you should lose sleep over. Face hit on the best suggestions previously.
    my rt35i manual said if you lay them on the side, put the tweets to the outside.
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
    Nothing will hapen to the speakers, but the imaging might suffer a bit.
    Hearing is believing.
    I was thinking about doing this with m40's because they are so tall!
Welcome!
Welcome!
