Need Laptop recommendation from CP
Erik Tracy
Erik Tracy Posts: 4,673
edited December 2009 in The Clubhouse
Hey all,
I'm in the market for my first laptop.
I'm thinking something with a >15" screen, basic apps is all (browser, MS Office Pro, Adobe Acrobat Pro to create PDFs, Photoshop, anti-virus, etc), DVD/CD writer, wireless, good running time of +2hrs, reliable, fast.
Would love to hear any recommendations/experiences folks have had with theirs - good or bad.
Any tips or features I should be concerned about?
Thanks!
Erik
  • PhantomOG
    PhantomOG Posts: 2,409
    make sure you think real hard about the screen size. I bought my first laptop a couple years ago and got a 17" screen. Now I really wish I had gotten something 15" or less.
  • KASR
    KASR Posts: 450
    I've had nothing but great luck with Sony Vaio's...all always recommend them.
  • coolsax
    coolsax Posts: 1,826
    I like a laptop of 15" or more but that's me b/c I play WOW on it. What kind of budget are you looking at? If you're looking just for basic use with little gaming then any of the $350-$600 laptops out there should be fine for you and last you quite a while. My wife and I have an HP and its done pretty well for us.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • audiobliss
    audiobliss Posts: 12,518
    I really love my Lenovo ThinkPad. Amazing build quality. Makes me so glad I chose a ThinkPad everytime I touch it. And I opted for a 14.1" screen. Makes it so much more portable.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Fireman32
    Fireman32 Posts: 4,845
    I work all day with the Lenovos but you are going to spend more money for one over the other brands. I also like the HP's. What is your price range?
  • Jstas
    Jstas Posts: 15,018
    Actually, I was looking at Dell's site the other day and they have some good deals on well equipped laptops for around $650-700. If you're not doing hardcore number crunching, that stuff will work just peachy.
    Expert Moron Extraordinaire
  • polkatese
    polkatese Posts: 6,767
    HP DV4-2040US - 14.1" screen, HDMI, 320gb, 4gb RAM yada yada.. is on sale at Office Depot $549 after HP $50 rebate.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Systems
    Systems Posts: 14,872
    Jstas wrote: »
    Yes, would recommend Dell also. My wife had an Inspiron which she used extensively for school, work, travel: took it with her wherever she went, never had issue one with it. She gave it too her sister after she got a another Dell and her sister loves it also.
    Her new Dell is a Studio 15 and have had no issues with that one either.
    Stay away from HP's, please:)
    Testing
    Testing
    Testing
  • tcrossma
    tcrossma Posts: 1,301
    I always recommend Dell. Relatively inexpensive and reliable enough for the 3-4 years that you'll likely want to keep it. I usually buy something from Dell's "small business" line since it usually works out a bit cheaper than their consumer line.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Erik Tracy
    I was thinking that my budget would be about $1K - out the door, all software loaded.
    But - if I can get everything for less - then more green for me to spend on audio stuff! :D
    I do alot of typing, so a notebook is not for me - I'm looking more for the full laptop with decent keyboard spacing.
  • tcrossma
    Erik Tracy wrote: »
    You might want to consider using OpenOffice to save some money. And between that and Photoshop you'll have pretty good PDF creation, so you might be able to do away with buying Acrobat (just depends on the type of PDF creation you need to do).
    As far as keyboards go, a lot of the smaller laptops these days have pretty darn good keyboards. I'd recommend that you don't discount a keyboard based solely on the screen size of the machine.
  • Jstas
    Jstas Posts: 15,018
    Erik Tracy wrote: »
    Yep. That's my preference too.
    Like Lorthos, my track record with Dell systems is good. Dell Support, they are a drag but thankfully I don't need to call them often at all since most of what I need is on the website.
    However, the $650-700 jobs are full-sized 15" and 17" Latitude models. They are the work horses. Also, like tcrossma said, check out the small business section instead of teh consumer section. you can get the "professional" and "ultra" levels of operating systems there instead of the limited "home" versions. Plus, systems are better equipped for similar money. Upgrades will be expensive there though so check prices.
  • SKsolutions
    SKsolutions Posts: 1,820
    HP 5310m == Great bang for the buck, less than 1'' thin, 5 hr battery life, good keyboard, magnesium and aluminum, low voltage but still very snappy Core 2 Duo. 899$
    Dell can't touch it.
    Review LINK
    -Ignorance is strength -
    billbillw Posts: 8,265
    If you want a notebook computer for doing serious work, I'd recommend getting a business class model from Dell, HP Compaq, or Lenovo. The Thinkpad is the model that most look up to, but the other manufacturers are worthy as well. I'd stick to 14" size for portability. The real benefit of the business models is the warranty. Consumer laptops usually only have 1 year warranty. Business models are usually 3 years and often will cover a battery replacement.
    Shop around at the places that do closeouts for slightly older business models. I managed to grab an HP Compaq business model (6910p) last summer for only $399 and that came with a 3y warranty, 14.1" screen, 7200rpm HDD (faster), 2.2GHz CoreDuo2, bluetooth, SD reader, firewire, and a real nice feeling keyboard.
  • Systems
    Once again, I can't stress enough, please stay away from HP's, Compaqs.....
    Testing
    Testing
    Testing
  • Conradicles
    Conradicles Posts: 6,432
    Just got my wife a Dell Inspirion for $500, it is a nice little gem.
  • Erik Tracy
    Lorthos wrote: »
    :( - my company has an employee discount program with HP/Compaq.
    I just used Dell's online tool to customize a Latitude 5500 and I ended up blowing my budget to $1600 even after their $300 instant discount.
    But - I will admit that I was adding some options in that I could probably do without.....:p
  • coolsax
    I've owned several HP and compaqs over the years been fine.
    Main 2ch -
    TV 3.1 system -
  • SKsolutions
    If you want to know whether a laptop is likely to prematurely fail, look for temperature readings throughout the body of the laptop, measured at all of the key areas. Online reviews are all over the place, and good ones will markup a picture with temperature readings taken after heavy use. If brand X sells millions of Celeron boxes, they will likely rate much higher on reliability, because they are clocked way down, and wont throw as much heat. If brand Y sells millions of desktop replacement, high clock Core 2 Duo Extremes or pretty much any AMD chip, and people game on them, they are exponentially more likely to fail. There is no data that is going to drill down to the exact model and configuration that you are looking to buy, so it's pretty much a crapshoot, and a wasted conversation. Look for heat and themal design. Don't get the fastest processor out there, get the most efficient. Lower total thermal envelope chips, and some of the newer low voltage chips are using newer materials for their transistors that lowers gate leakage and loss quite a bit. Heat kills laptops. Finding a cool running one is the best predictor of reliability and quality of design, not brand. Again, the parts are likely identical.
  • Jstas
    Jstas Posts: 15,018
    The HP may only be $899 but if you read the fine print, you also must sell your soul to own one.
    Honestly, the HP systems will perform but they are very proprietary and it's hard to get replacement/upgrade parts for them. They are also expensive parts. Many other systems from other manufacturers are much easier to deal with and upgrade in that respect.
    Personally, I'm not a fan of the HP systems. I try to stay away from them for the above reason alone. That and I like my soul. But to each his own. All I know is that I'm picky about my systems and I was able to find, customize and price a laptop from Dell well below the $1K mark set and I was happy with the selection.
  • tcrossma
    Erik Tracy wrote: »
    A Dell Vostro configured the way I'd want is $649, and that's more expensive than I usually go.
    I just can't see spending much more on a computer these days. I'd rather get a relatively inexpensive one today, use it for 2-3 years, and then get a new one instead of spending double that and being forced to keep it longer. Even a modestly configured computer right now is plenty fast and has all of the features that I need for my tasks.
    But, everyone has their computing needs and wants. I've just realized that mine do not include getting the latest / greatest hardware anymore -- I'd rather use the money on something else that matters more to me.
  • vc69
    vc69 Posts: 2,500
    I always recommend Dell. Nobody has ever regretted my suggested purchase. I use a ton (literally... maybe more) of Dell Latitudes and Vostro's (a few) and the Vostro's are good budget laptops.
    /.02
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • steveinaz
    steveinaz Posts: 19,546
    Lorthos wrote: »
    CORRECT. They have the highest failure rates in the industry. Toshiba is the best rated for not failing.
    HP consumer laptops may be the worst for reliability, but their business models are stout, that's why they carry a 3 year warranty!
    Squaretrade (warranty company) did an analysis of repair rates on the various laptop companies. Asus, Toshiba, and Sony were neck and neck for the lowest failure rate. But remember, this is most likely looking at consumer models since most business models don't get a squaretrade warranty tacked on at purchase time (because they already have a longer warranty ;) )
    http://www.squaretrade.com/htm/pdf/SquareTrade_laptop_reliability_1109.pdf
  • phuz
    phuz Posts: 2,372
    It's hard to beat Dell. Period.
  • edbert
    edbert Posts: 1,041
    phuz wrote: »
    Not so much. Walk to garage, open toolbox, pickup hammer, proceed as necessary.
    No one has mentioned it, but you could always get a Macbook. It should do everything you are requesting and they are quite reliable(at least in my experience). The price falls right where you are looking. Other than that, my dad, father-in-law, brother-in-laws and sister all have Dell laptops and they have yet to have problems. Most of them are on their second ones just because they needed to upgrade to keep up with their computing needs.
    Good luck!
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    KASR wrote: »
    My vote use to go to HP but they seem to have went down FAST with their quality. Everything form motherboards going to power supplies to the cords. Now I can not comment on their newest ones. Also I do not recommended dell at all. Why? Just a PITA to get parts and support for. I have had to work on them a lot and do not care for them.
    Now personally I have a 5 year old mac that I swear by. 0 problems. however I am not sure if that it the route you want to go.
    So my vote as well goes for sony.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • Erik Tracy
    So, I've narrowed my selection down to two laptops:
    Toshiba Satellite M500-ST6422 $878
    Dell Inspiron 15 $875
    Both comparably configured with screen size, Win 7 OS, 4GB memory, comparable HD, MS Office, etc.
    Any thoughts?
  • ViperZ
    ViperZ Posts: 2,046
    I would never buy anything but the Thinkpads. Built like tanks, perform excellent. Negatives? Butt-ugly, but it's worth it.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • WilliamM2
    WilliamM2 Posts: 4,818
    At work we now buy Asus, Toshiba, and Lenovo laptopa. All have been very reliable.
    Over the years we have purchased HP, Compaq and Dell as well, they all seem about the same for reliability, not horrible, but not as good as the ones mentioned above.
    I do disagree about HP/Compaq being more proprietary and harder to upgrade though. All laptops are proprietary, drive and memory upgrades are about all you can do with any of them.
