tweeter id question
turbopantera
turbopantera Posts: 35
edited December 2009 in Vintage Speakers
I am trying to id a polk tweeter I have. It was in one of the speakers I bought but is not an original tweeter for that model speaker. It has the same frame style as the SL2000. However, it is a shiny black colored textile softdome. It has no markings other than saying polk audio around the front in a circular pattern. Can someone tell me the model number of this tweeter and any particulars about it. I am considering replacing the SL2000s in my SRSs with this tweeter.
Dave
In love with SDA since 1984
2CH: SDA SRS (new caps) with NAD 541I, NAD 917 and modded Phase 400 (soon to be NAD 208)
HT: SDA 1C (new caps, SL2500s, bass mod) with NAD T763 and Monitor 4 as surround
Other vintage stuff, Sansui G9000, Pioneer 1980
Post edited by turbopantera on
  • mmadden28
    mmadden28 Posts: 4,283
    Sounds like the RD0-194, the new and more desirable replacement for the SL2000.
    Which model speaker did you buy that this came in?
    Which model SRS do you have?
    ____________________
    Pool: Atrium 60's/45's
    F1nut Posts: 52,000
    It also fits the description of the SL2500, which is not designed to work in any SDA speaker. I'm not sure how to tell the difference between the SL2500 and the newer RD0194-1. Perhaps someone else will chime in on that.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    You look at the sticker on the back.
    F1nut Posts: 52,000
    Would the SL2500 have a label? The RDO194-1 does not.
  • skrol
    skrol Posts: 3,460
    The face plates are textured differently and the SL2500 seems to be a little more refined in the manufacturing but it is hard to describe. The easiest way to tell is that the SL2500 has a foam ring around the dome, the RDO-194 does not.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • turbopantera
    It looks like my mystery speaker may be an RDO 198. I have SL2500s in my 1Cs but I know it is not a 2500 since the 2500 is not a textile dome.
    Dave
  • shadowofnight
    shadowofnight Posts: 2,735
    skrol wrote: »
    Also the magnet/pole piece assy is held on with torx head screws in the 2500....the RDO's use philips head screws.
    The first rule of Fight Club is you don't talk about Fight Club
  • mmadden28
    skrol wrote: »
    From the pics, the 2500 also appears to stick out a bit more-more rounded, where the 194 is closer to flat.
  • shadowofnight
    Here is another close shot of the 2500...
  • mmadden28
    While where at it---what does the 198 look like? Or should I say, how can it be identified or differentiated from the 194?
    heiney9 Posts: 25,497
    Does it have foam ring around the dome between the dome and the bezel? If so it's either a sl2500 or sl3000. Many of the sl3000's are actually a copper or gold tint to the dome.
    If it has a dark black dome and no foam it's the newer RD0194-1 or RD0198-1 tweeter.
    mmadden28 wrote: »
    The spade terminals are different sizes for one model and the other model has the same size spade terminals. I forget which is which. IIRC, the 198-1 has the same size spade terminals and the 194-1 has one large and one small spade terminal.
  • skrol
    skrol Posts: 3,460
    My RDO-198's have one large and one small terminal.
    Stan
    Main 2ch:
    HT:
    Other stuff:
