Tube amp newbie needs some love
Vandam
Vandam Posts: 22
edited December 2009 in 2 Channel Audio
Hi Everyone,
Long time lurker, first time poster.
There is a wealth of knowledge on this forum, and I appreciate your help with the following question.
I am hoping to dip my toes in the Integrated Tube Amp pool. I've read a lot, learned a bit, and found most of it a bit over my head. I would like to buy a good, 2 channel tube amp that I could add into a small bedroom system I am building. My wife won't be too thrilled with my Monitor 10's in the bedroom, so I'll have to live with some small bookshelf speakers. Keep that in mind if you recommend a nice integrated tube amp.
So, can any of you list a few tube amps that I could google, search for information on? I would prefer to go 'new' if at all possible. I am not all that technically savvy, and really don't feel lucky in buying used...at least not at this time. Maybe after I have cut my teeth on something to learn with.
All help, hints, tips are appreciated!
ps...what the hell does 'rolling tubes' mean?
Post edited by Vandam on
  • thsmith
    thsmith Posts: 6,082
    Welcome to CP.
    Tube rolling is rolling different tubes into your amp/pre/phone/whatever with differnt tubes for a different sound.
    Before making a recommendation on a integrated tube amp it would be good to know what speakers you plan to use their efficiency rating. You might be ok with a 5watt or 50watt amp, depends on your speakers.
    Or I guess you could buy your intergated first and find the speakers to match.
    This might be a good place to start.
    http://www.daredtube.com/products.htm
  • Systems
    Systems Posts: 14,873
    If I was just getting my feet wet in tubes but wanted to jump right into tube rolling I'd look into a 6550 based unit. Most of these can use 6550's or KT88's in the power / output section. You'll most likely find something like 12AU7's, 12AX7's, 12AT7's, 5751's, 6SN7's in the input or driver stage of the amp. Lots of tube choices with an amp like this with tons of combinations to explore. I believe Prima Luna makes an intergrated that will use almost any power tube that will fit in the socket???? EL34, 6CA7, 6550, KT77, KT88 and so on. As Mr. Smith mentioned above speaker selection will play a BIG part in the choices you make also. A 5wpc - 10wpc amp isn't going to give you what you want with a speaker that is 86db efficient.
    BTW...welcome to the show.
    Testing
    Testing
    Testing
  • halo71
    halo71 Posts: 4,630
    When someone asks me about which tube guitar amp to choose. One of my first questions is what is their budget. Might be a good starting point here as well.
    --Gary--
  • Systems
    halo71 wrote: »
    The budget was blown when he decided to go to tubes and mentioned 'rolling' :D
    Testing
    Testing
    Testing
  • halo71
    halo71 Posts: 4,630
    ^ Oh my bad. I am a noob to hifi tube amps as well. :o
    --Gary--
  • Vandam
    Vandam Posts: 22
    Thanks for the responses so far, much appreciated.
    I do not yet have speakers that I have designated for it...I would prefer to start with the amp, and then find some high efficiency speakers to match up with it. The budget..well, you know how that goes - I want everything, for nothing. :D
    Around $1000?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    You seek a used Manley Stingray look for one on Audiogon an new one will blow your budget. These have a very high wife approval factor. They are also highly regarded for build and sound quality.
    This one just sold but you will get the idea
    http://www.audiogon.com/cgi-bin/cls.pl?intatube&1264186553&/Manley-Stingray-price-drop
    Others to consider are Jolida, Joule, and Vincent.
    Welcome to CP.
    RT1
