Interesting article about a read interesting engine design
Jstas
Jstas Posts: 14,842
edited December 2009 in The Clubhouse
http://www.autoblog.com/2009/11/30/autoline-on-autoblog-with-john-mcelroy/
From the article:
Eco Motors is the name of a new company that has come up with a radically new type of engine. It has two opposing pistons in two contiguous cylinders, connected to a common crankshaft in the middle of the engine. An electric supercharger provides boost on demand. It's a two-stroke engine with no valves, yet still achieves 90% scavenging efficiency with less oil consumption than a four-stroke engine. In other words, it's a two-stroke engine that can meet the strictest emissions standards. It can be made as a spark-ignited or compression-ignition engine, and the diesel version can meet emission standards without using urea.
Expert Moron Extraordinaire
Post edited by Jstas on
  • edbert
    edbert Posts: 1,041
    Very interesting!
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Also interesting, is that the designer is the same man who designed the VR6 for VW.
  • ShinAce
    ShinAce Posts: 1,194
    I'm not in the loop, but the article seems to think so:
    "Just as importantly, the OPOC engine was designed by Peter Hofbauer, who spent 20 years at Volkswagen designing diesel engines and the VR6, that narrow 15-degree engine."
    mhardy6647 Posts: 33,919
    Thought that said OPEC engine...
  • audiobliss
    audiobliss Posts: 12,518
    Wow, that's really amazing! Never would have IMAGINED a design like that. Even after reading the description. I was picturing it wrong 'til I saw the vids. It'd be cool if this actually took off and went somewhere.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    Tony M Posts: 11,164
    I feel there has to be a third cylinder introduced to prevent 180 degree lock-up...No?
    I liked the Wankel design. Three worked there If I remember right.
  • Jstas
    Jstas Posts: 14,842
    A Wankel engine has no pistons. It's otherwise known as a rotary engine.
    The rotor in a Wankel is effectively triangular; the combustion/exhaust chambers sort of "figure 8" shaped (IIRC).
