Denon AV 4310 and LSi15 Compatibility
devi_pathy
Iam planning for a HT system with the following configuration. Pls let me know whether the set-up considered will give me optimal performance:
1. Denon AVR4310
2. LSi15 - 1 pair
3. LSiC - 1 no
4. LSiW - 1no
5. LSiFX - 1 pair (at sides)
6. FXIA 6 - 1 pair (at the rear)
Let me know whether Denon 4310 will be able to drive the above set-up. Is there any other optimal configuration?
1. Denon AVR4310
2. LSi15 - 1 pair
3. LSiC - 1 no
4. LSiW - 1no
Post edited by devi_pathy on
The Denon will not drive the LSi's sufficiently, you will need to add a seperate amp. There are dozens of posts with Denon's and Amps, do a search you'll find the best amps to use. I recommend the Outlaw products.
www.outlawaudio.comDenon 3806 Receiver
Denon 3910 DVD
Oppo BDP-83 Blu-Ray
Outlaw 7500 300w x 5 @4 Ohms Amp
58" Panasonic 800U 1080P Plasma TV
SVS PB-12 Plus Sub
Lsi25 Fronts-Cherry
LsiC Center
LsiFX Surrounds
SMS-1 Velo Sub EQ
PBJ Interconnects
Blue Jeans Cables
Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?" -
I recommend the Sunfire products.
http://www.sunfire.com/productdetail.asp?id=3
http://www.polkaudio.com/forums/showthread.php?t=89779
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's:D
03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
05) HITACHI P55T501. 55" HD1080 Plasma HDTV
06) POLKAUDIO LSiC (Center speaker)
07) POLKAUDIO LSi15 LEFT (Front speaker)
08) POLKAUDIO LSi15 RIGHT (Front speaker)
09) POLKAUDIO LSif/x LEFT (Surround speaker)
10) POLKAUDIO LSif/x RIGHT (Surround speaker)
11) VELODYNE OPTIMUN 12" (High Output Digital EQ SubWoofer 2400W/1200WRMS) -
Good suggestions above....but go "used" unless you can afford new...
I'll throw in ROTEL and Parasound into that mix!
