Minimizing reflections
Strong Bad
Strong Bad Posts: 4,278
edited April 2003 in Speakers
Hey guys,
I'm thinking of adding some sound deadening materials to my side walls to minimize the reflections from my SDA-SRS 2.3's. They're setup about a foot from the side walls right now and I don't have room to spare. The walls are:
1. Killing the SDA effect
2. Making them sound bright due to the hard surface reflections
Any ideas or suggestions? Please post links to any manufacturers or e-tailers that make the right materials.
Thanks all,
John
No excuses!
  • Ron-P
    Ron-P Posts: 8,519
    edited April 2003
    Standard hard-pressed insulation 1" thick covered with your choice of fabric will work perfectly. I raided a theater during demo and that is all that was used throughout.
    Because your only after killing reflections and not after sound proofing, I'd start with just some fabric hung on the walls at refelction points first and work up from there.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
