monitor 7-c vs monitor 5 ?
fomoco69
What is the main difference? and what is the impiedance----ohms? 4 - 8
Post edited by fomoco69 on
Monitor 7's use a bigger cabinet and bigger passive radiator.
thanx.......what is the ohms on those?
I think someone answered your question in another thread. They said 6ohms.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
The 7C's are 6 ohm, but depending on what version of 5's you have it differs. I have the matching 5b's and they are a little less than 6 ohm, but would not consider them 4 ohm like some of literature says. I think they tested closer to 5 ohm, and are noticable more effecient than the 7's. Bass is much deeper with the 7's, but the rest is about the same.
If you plan on using a sub, both are great options! Stand alone and speaker size not an issue, I would take the 7's -
I am using a 1997 TEAC 130 watt reciever & was concerned about the ohms.........my 5's seem to be fine?
If your 5's are fine, then you'll be ok! I have 2 pairs of 7c's and really like them, they are great speaker's....the old rule, the bigger the cabinet space the deeper the bass.
I am sure this is totally subjective, but I love my 10s, really like the 5s and the 7s are good....I have only had a couple pair so maybe I just haven't had a really quality pair...and then there is that a, b, c thing that Polk has with so many of the Monitors....
according to Polk Audio Specs the 7's are 8 ohms
http://www.polkaudio.com/homeaudio/specs/recent/monitor7/ -
That is the specs for Monitor 7 series 2, not for a monitor 7C...All Series 2 Monitor's were 8 ohm, while the older versions were 6 ohm. I attached the Monitor manual for the 7C and 5B, as well as the rest of monitor line. I hope it helps out!
That's the M7 Series II...the older 7's are 6 ohms nominal.
The only real differences between 5's and 7's are the cabinet size, and the 10" PR in the 7's versus the 8" PR in the 5's. IIRC, the 5's and 7's generally used the same MW's. The crossovers are basically identical as well, aside from the unpredictable variations that Polk is so well known for.;)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
