OWM's and RTi8
mrbofus
mrbofus Posts: 297
edited November 2009 in Speakers
Anyone have experience with these new OWM5 / 3's running with RTi8's?
I have been looking at them and almost have the wife sold on the idea because of the layout of the room, High wall mounts would work the best.
Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Onkyo DX-C390 CD Changer
POLK RTI8 Mains--Cherry
the rest...in process...slowly!!
Post edited by mrbofus on
  • rallyshark
    rallyshark Posts: 417
    I have the OWM 5s and really like them. They were made to work well with most of Polks speakers I believe. If you're using them for surrounds, they would probably work just fine. They seem to have a pretty "neutral" sound to me. I'm no expert though:o As long as you keep them crossed over above 80-100hz, they can work great for many applications. I can't tell you for sure for you situation as I've never heard the RTi8s. I'm sure someone on here with much more expertise than I will chime in:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • dorokusai
    dorokusai Posts: 25,576
    It would be a great choice for that application.
  • mrbofus
    mrbofus Posts: 297
    dorokusai wrote: »
    Thanks,
    As far as placement goes, The best place would be directly behind the couch where the wall and the ceiling meet. placing them on the sides at ear level isnt an option. Would be be a issue?
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
  • packetjones
    packetjones Posts: 1,059
    I have had the OWM3's and thought that worked very well as a surround speaker. I had them corner mounted behind my chairs. The only issue i would see with mounting htem near the celing is if the couch is all the way against the wall. Even then i am sure it would be ok. Maybe not the optimal location but if it is the only place it is the only place.
    Getting the wife to approve is the biggest part. If she likes it then i would go ahead and do it. It would be better than not having surrounds at all. lol
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • dorokusai
    mrbofus wrote: »
    Thanks,
    At the wall/ceiling joint, angled down, would be perfect.
  • mrbofus
    mrbofus Posts: 297
    My couch is about 4 ft off the wall so sounds like that should work.
    Thanks again guys!
    Greg
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
