Intelliflo Pentair Pool Pump
disneyjoe7
disneyjoe7 Posts: 11,435
edited October 2011 in The Clubhouse
I need to replace my pool pump motor as it smoked Thanksgiving day :eek:
The cheap way would be just to replace motor, but the cost to run pump I consider the Intelliflo pump instead. Feeling the cost difference I could recover in a couple years or less in the difference in running. I confused on what model I should do.
There's a 4x160 which has 4 speeds but may have 8? with Intellitouch control which I own. 4 speeds could be just fine I can figure right now. Then there's a VF model which can be varied in speed by the Intellitouch control just not sure if the cost + of that pump justifies the difference over the 4X160 pump. Then I wonder if these pumps are the same as in pump, motor but are different by the motor controller only.
Does anyone know anything or use this pump?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • mrbigbluelight
    mrbigbluelight Posts: 9,888
    edited October 2011
    You know, I was just about to suggest that to DJ myself: "You've just need to have your time to make research"..
    Next long weekend you have, disneyjoe, you may want to consider dropping by Riverside, California and picking up some pool supplies. Maybe a Nokia phone ? It's been almost 2 years since your original post, so I imagine that you may been running low.
    "DAD !"
    What ?
    "STOP IT !"
    But .... Oh, okay ..... dam ....
    So ..... uhm ...... okay. :redface:
  • disneyjoe7
    edited October 2011
    Well I quest an update would be nice.
    I replaced it with an Intelliflo VS pump which is controlled by the Intellitouch controller via a data line. The pump runs 18 gpm normal and 40 gpm if Solar, water flow, or deck jets or in use. All in all couldn't be happier with the setup, or the power savings over the old pump.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
