Bass floating about 1ft above listening/seating position...how do I bring it down?
KASR
Like the title says: my bass is floating about 1 foot above main listening/seating position - what can I do to lower it? The bass is positioned for the best response, however it's floating. Any ideas gang?
Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro
Post edited by KASR on
Room treatments, bass traps, speaker positioning, listening position...experiment."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Try moving the sub to another location with the same phase setting. If this doesn't work, flip the phase and try different locations.All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
I'll give the phase a try - thanks! If that doesn't work, I guess I'm back to crawling on the floor!Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
It sounds like you have a null in the listening position. Change the location of the sub or [possibly] mains to correct the issue.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Tell the bass player to get off the bar and back on the stage where he belongs.:D
Sorry couldn't resist. As others have already said try playing with the set up: location, phase. If you sit in a couple different locations does it sound the same (floating)? Set up is probably the best place to start because it's free, just can be time consuming and really not as easy as one would think. -
Sound like KASR is describing a null to me too. Very common actually. Not as easy to fix if you are committed to your listening position and/or your speaker placement.
You are going to have to move some stuff around. Null and hot spots... fun fun fun.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Definitely this. Placement is the only cure.Shoot the jumper.....................BALLIN.............!!!!!
I think this assessment is spot on...I did a walk-around the room and discovered some interesting points. See attached image.Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro
