6503s are they the one??
geppy1
Iy seems as though the 6503 driver was used in many top of the line speakers and others toward the end of the vintage era. As I recall a number of years ago if you needed a replacement driver from Polk regardless of what you had ( 6500,6501,6600 ect) the 6503 was the replacement. If a guy had access to a bunch of 6503s should he replace say 6600s in the RTA 12Bs, 6511 and 6510s in SDA1cS? or, is this a bad idea?
I asked this questiona while ago and only Ben responded. What is the real difference between the 6500,6501 and 6600?? They all sound different. Polk made a big deal about the 6600 Keith
