SDA CRS+ 6 ohm Question
JohnLocke88
JohnLocke88 Posts: 1,150
edited November 2009 in Electronics
I'm sure this will be a quick answer to someone more knowledgeable than myself. Tried to search, but for some reason, I seem to suck at using the CP search feature.
I recently acquired a pair of nice CRS+ which I know are 6 ohm. I'm in the process of acquiring a nice little tube amp to drive them. However, on the back of the amp, there are the standard Ground, 4 ohm, 8 ohm and 16 ohm connectors. With the CRS+, should I hook them up to the 4 or 8 ohm connectors?
Also, is it safe to power them with a tube amp with only 8 ohm or 16 ohm outputs?
Thanks in advance for the help guys.
Post edited by JohnLocke88 on
    F1nut Posts: 51,769
    Try both taps to decide which sounds better to your ears.
    Should be ok, but only on the 8 ohm tap.
  • JohnLocke88
    Okay Good... Just wanted to make sure one wouldn't blow anything up.
  • xj4094dg
    xj4094dg Posts: 1,158
    Congrats on the +'s John. I love mine, I'm hoping to do the tl upgrade in January. Enjoy!
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • apphd
    apphd Posts: 1,514
    John, congrats on the CRS+ you should be very happy! After all the SDA's are well regarded today just as much as when they were produced, and to top it off they are the Compact Reference System component of the series.;)
