HomeTech Outdoor Speakers
Ron-P
Ron-P Posts: 8,520
edited April 2003 in Speakers
Just about to slap down some green for the outdoor's and I found some never before heard of brand "HomeTech" speaker's on Best Buy's website. I was in line with the Polk Atruim's but these have better spec's at half the price. Anyone have or heard'em. I'm headed over at lunch in hope's they have a pair wired of listening.
Polk Atrium45's
Mid/Woofer 1 - 4-1/2"
Tweeter 1 - 3/4" Diameter
Overall Frequency Response 75Hz - 20kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 10 - 80 w/channel
Power Handling (continuous) 80 w
Power Handling (peak) 160 w
Efficiency 89 dB
HomeTech
5-1/4" polypropylene cone woofer with rubber surround
5/8" polycarbonate tweeter
Frequency response: 55Hz - 20kHz
Sensitivity: 90dB
Power-handling capacity: 80 watts
Impedance: 8 ohms
Peace Out~:D
If...
Ron loves a film = don't even rent.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2003
    What's better? They play a little deeper? Did you look at M2's? The M2's will play *that* deep, and you won't have a tinny Mylar tweeter.
    Heard em both, the Atrium is by far the better sounding speaker of the 2.
    Cmon Ron, 'home tech'? Sheesh.
    Cheers,
    Russ
  • Ron-P
    Ron-P Posts: 8,520
    edited April 2003
    I know Russ, I know. I just don't want to dump 2 Franklin's for Outdoor's and I'd rather not order them off ebay to save a few coins.
    I've gotta give'em a listen. I've heard the Atrium's at CC so I gotta give these a shot. I'm after inexpensive as they will be out front and visible from the street.
    Peace Out~:D
    If...
  • RuSsMaN
    edited April 2003
    Roger that, hell, you may like em enough to do the job. I run cheap-o's out back for 2 reasons, visible from street (corner lot), and they do what they need to.
    Only problem so far is having to replace them after every Texas summer, but at a cheap price, hell, they're disposable. While you are there, might as well check out the $30/pair KLH's too.
    Just didn't want you deciding on specs alone, which doesn't appear as what you were going to do anyway. ;)
    Cheers,
    Russ
  • ChrisDurano
    ChrisDurano Posts: 372
    edited April 2003
    Peace Out~:D [/B]
    ....what....are you going to be yelling some propoganda to the neighborhood or somethin'?:D
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • shack
    shack Posts: 11,154
    edited April 2003
    Ron, another option is the JBL Northridge series. I have the JBL N24AW which I picked up for less than $100 from Harman Audio. I noticed they have the N24AWII $149 on the web site (I don't know what the II represents in the way of improvement). I noticed they have the JBL N26AW for $128 which is a nice deal. I like the sound of them a lot, especially for an outdoor speaker. I wanted the Atrium 45s but I didn't want fo pay that much for them. BB sells the JBLs. Go give them a listen then check out Harman Audio.
    http://www.harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=N26AW-Z
    http://www.harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=N24AWII-Z
  • RuSsMaN
    edited April 2003
    Shack, those JBL come with a bracket? Didn't see one listed.
  • Ron-P
    Ron-P Posts: 8,520
    edited April 2003
    Check'en the CC website, they have some Jensen Satellite's for $34/pair. They are small and might just do the job as well. I gotta give these a listen as well.
    These are only for some back'round noise during BBQ's and the like, they'll never get cranked so preformance is not a big issue at all.
    Thanks for the other heads up guys. It's just about lunch time. I'll report back.
    Peace Out~:D
    If...
  • setzer808
    setzer808 Posts: 173
    edited April 2003
    Not on topic, but hey, how do you get that little red "system" icon on your posts. I have my system posted already, but saw no option to add that.
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
    Polk PSW-350 Sub -in storage.
    Yamaha RX-V681 A/V Reciever
    Sony SCD-CE595 SACD Player
  • shack
    shack Posts: 11,154
    edited April 2003
    My N24AWs did. It is a swivel mount that can be used for mounting on the wall or hanging from under the eves. I don't know about the N26s.
  • Ron-P
    Ron-P Posts: 8,520
    edited April 2003
    The quest continues. No luck at CC, the white colored Jensen's were outta stock. But, they had a black pair on display, not a bad sounding little speaker for $15 a pop, but not quite enough for an outside location where noise and chatter will abound. Never made it to BB, had to hit Lowe's, Home Depot and the gas station first...ran outta time.
    Peace Out~:D
    If...
  • fireshoes
    fireshoes Posts: 3,167
    edited April 2003
    I was in line with the Polk Atruim's but these have better spec's at half the price.Polk Atrium45's
    I keep looking for that 'better sound' spec but it's never listed. :confused: Hahaha
  • ChrisDurano
    edited April 2003
    Acoustic Research Edge Multipurpose Speakers
    ...these don't look too shabby for their price either.
  • Ron-P
    Ron-P Posts: 8,520
    edited April 2003
    Landed the HomeTech's today. BB put them on sale at 40% off, they ran $59.00. I'll feed'em some tunes tonight and hear what they sound like.
    Peace Out~:D
    If...
