Monitor 10B - Rebox, replace tweeters?
lagavulin996
lagavulin996 Posts: 6
edited November 2009 in Speakers
Just wondering if anyone has replaced the original tweeters and/or reboxed them to get a better look?
I had mine done about 15 years ago - all black semi gloss mica finish (same size box) w original grills. Also switched to a Vifa tweeter and had the cross overs rebuilt with newer components (and to match the tweeter). Reproduced a set of I stands in the matching fisinsh as well.
My original tweeters would always trip, and the speakers sounded slightly different when run in isolation and then compared. Now they are identical (after the cross over upgrade).
Post edited by lagavulin996 on
    heiney9 Posts: 25,432
    So they're not really Polk 10B's anymore.
  • lagavulin996
    LOL! I guess not. But they do look and sound better. :)
    Toolfan66 Posts: 18,057
    custom speakers with a few polk parts, no longer a polk speaker.
    If they sound good then enjoy!!!
