Velodyne DLS4000R
dfledezma
Hi everyone.
So finally I bought a subwoofer, a Velodyne DLS-4000R. I´m very happy with with, however I´m having some trouble setting up the bass correctly. The thing is that it doesn´t have a volume knob, only buttons, and the remote. Normally there is a recommended volume setting in the knob but I´m not sure how to set it up at the correct volume.
I know is a matter of taste at some extent, but I´m constantly changing the volume for different sources, so I would like to try a recommended volume.
Post edited by dfledezma on
Not following you...I have different settings for 2 channel vs. HT and I even tweak the HT setting if I want to run the sub 'hot'. I don't think there is ONE recommended setting for any sub, at least in my opinion..
Perhaps others disagree.....set the Velo to 12 o-clock or half volume and use the test tones on your AVR to tweak its loudness. Once I set my sub volume I don't bother with the sub anymore I use the AVR to adjust the signal...increasing or decreasing the base as necessary.
Well, what I want to do is precisely to set the volume at half, in order to adjust it. But I don´t know how to determine when the volume is at half, since it has no volume knob, but a pair of buttons to adjust the volume.
The only volume indicator is the blinking light at the front, but is a bit difficult to tell anyway -
It seems they did this so you just give it a boost with the remote supplied with your sub. In that case I would set your receiver to zero and adjust your sub. if not it seems you will have to guess.
Over at AVSforum under subs and Velodyne there is guy there from Velo that is very helpful. From what I remember the number of flashes tells you what the volume level is set to.
It might be easier to set the sub and adjust the gain at the AVR. If you are constantly having to change your sub volume I would tend to think it is not set up right onm the sub or AVR, ymmvSpeakers: SDA-1C (most all the goodies)
Yup! Blue light on the left indicate's volume level, for example setting it at 3/4 or 75% would show 7 slow blink's followed by 5 quick blink's, setting at 1/2 or 50% would be 5 slow blink's and then solid, etc, etc....
Quite simple really, just make shure that you have the light turned on as there is a button on the remote to turn it off
There is also volume button's on the plate amp if you look
I suggest reading the manual if you haven't already as it is pretty straightforward to use
I find myself playing with the setting's often to achieve my "best" sound
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
Many thanks!! I´ll play around once I get home. I still have much to to in order to get the best sound, playing with settings, positioning the speakers, etc etc
YES they are correct the volume is measured by the blinking blue light. I believe the MAX volume is 99. I don't ever put mine higher then 40. It is killer at that volume. Play with it to see where you like it. Velodyne makes an AWSOME sub. Good Luck.TV- 52 inch LCD SONY BRAVIA XBR6
TV- 42 inch PLASMA HITACHI ULTRA VISION
AMP- PARASOUND HALO A-51
CONTROLLER- PARASOUND HALO C-2
FRONT SPEAKERS- LSi15's and LSiC
REAR SPEAKERS- LSi7's
SUBWOOFER- VELODYNE DD15
BLU RAY- LG SUPER BLU BH200
BLU RAY- SONY BDPS350
GAME SYSTEM- NINTENDO Wii
MONSTER POWER CONDITIONER
WIRES- AUDIO QUEST and MONSTER
