Maple Speaker Stands
MillerLiteScott
MillerLiteScott Posts: 2,564
edited November 2009 in DIY, Mods & Tweaks
A couple of days ago I laminate 16 pieces of 3/4"X3 1/2"X3' Maple and today I cut them into 12" X 17" blocks and ran them through the planer, joiner and sanded them down to get ready for some finish.
I made them for my SDA 2B's. I am going to spike them and sit them on my carpet over basement slab and then sit my SDA 2B's that I recently installed 3 through bolted bolts and T-nuts with spikes. I currently just have my speakers spiked on 2" thick bluestone slabs that are also 12"X17" and just sitting on the carpet.
I am looking forward to hearing if it makes a difference, and I am hoping it will be positive.
I will follow up with my findings as the project progresses.
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Nice looking block of wood there, great looking start look forward when you get them done.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • strider
    strider Posts: 2,568
    Helluva idea. Leftovers from a job?
    They will definitely look good and, I would think, sound just as good.
    Wristwatch--->Crisco
  • Face
    Face Posts: 14,340
    Looks great!
  • MillerLiteScott
    No Ben, I actually had to buy the lumber. They actually turned out pretty nice, I am quite pleased with the results.
    Scott
  • hearingimpared
    hearingimpared Posts: 21,136
  • BlueFox
    BlueFox Posts: 15,250
    I purchased 4" thick maple speaker stands with heavy brass footers from Mapleshade, and it made a big differance in the sound. Definitely clearer, in fact it was also brighter. At first I thought it was due to the tweeter being higher, and that might have played a part. I ended up reinstalling the speaker grills, and adding some Auralex foam behind the speakers, and that bought the brightness down while still sounding better. The speakers are PSB Synchrony One towers which replaced my SDA-2 speakers.
    Later I upgraded my speaker wire and I realized the wire was a big part of the brightness as the new wire was clearer, but not as bright, and had better bass response for an overall sound improvement.
    Anyway, Mapleshade says carpet over concrete is one of the worst things for speakers to be on, and that is why I bought the maple speaker stands. You should do fine if their 'theory' is correct.
