Satellites to Floorstanding & Subwoofers
HDTD
HDTD Posts: 1
I recently upgraded my RM 7200 Satellite speaker system to floorstanding Tsi 300 fronts and a CS 10 center. I will soon be adding a new subwoofer as well -- probably a PSW 505 or something comparable.
Question: With the old satellite set-up Polk recommended the speaker level connections. Now that I have floorstanding speakers should I switch to a LFE input? Which will give me the better sound?
AVR: Pioneer VSX-1018AH
Front: TSI 300
Center: CS 10
Surround: RM 3300
  • thuffman03
    thuffman03 Posts: 1,325
    edited November 2009
    Try it both ways and see what you like better.
    I have found IMO that for 2 channel listing I like going to the sub and then to the speakers. In HT setup I like have the sub on the LFE. Right now I don't have a sub on my HT but my L/R speakers go down to 20hz which works fine for most movies but for action movies I think having a sub on the LFE sounds better.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
