momo add on
Systems
I had the momo mm6 components installed in the front doors of a new Vibe and was wondering what kind of speakers I should get in the back doors. I do not want to have subs in my car and really didn't think I needed two sets of components, so is it better to get a set of Polk coaxials (maybe waiting for momo's if their going to come out with some) or to get just a midrange woofer like the JL Audio XR650-CW?
Testing
Testing
Testing
Testing
Testing
what kind size speakers do you have in the back?
and dont get JL, you dont get what you pay for
-Cody -
There are 6 1/2" speakers in the back door. The same size as in the front. Should I stick to one brand of speaker or does it not really matter?Testing
Testing
Testing -
use coaxials -- cheaper... easier -- hell you're not in back, you're in front.. u just want rear fill.
if you dont want to wait for polk momo coax to come out in summer.... just get the polk DX or DB 6.5" coaxials... they're just as loud and clean as the momo - the DB coax might actually sound better.
u can find a set on ebay for 50 dollars shipped usually used -- 75 - 100 shipped new. they're not in production anymore.The Artist formerly known as PoweredByDodge
