New amp, how to wire?
nacam
Hi All;
I finally picked up some somewhat serious power for my 1.2TL's today. I went with a Rotel RB-1090 (380wpc @ 8 Ohms). Currently I am "bi-amping" my 1.2TL's with a Rotel RB-985 MKII (using 4 channels/2 for each speaker). That being said I have 2 pairs of wires running to each 1.2TL's. My RB-1090 has two sets of binding posts for "bi-wiring" speakers (as stated in the manual). My question is:
Do I put the HF/LF jumpers back on the 1.2's and connect all 4 wires to the back of the amp or leave them off?
Thanks in advance.
Thanks in advance.
2 Channel Basement Setup:
PC With M-Audio Audiophile 24/96 Card
Rotel RC-1070
Rotel RB-1090
Polk Audio SDA SRS 1.2TL (1991) w/RD0-198 Tweeters.
Rotel RC-1070
Rotel RB-1090
Post edited by nacam on
If you're using all binding posts on the speakers, as far as I know yea you would have to remove the jumpers.
Btw, congrats on the amp!Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
If you have a speaker cable going to each binding post,then you should remove the jumpers.Don't throw them away,put em' somewhere safe.Good luck and have fun.JC approves....he told me so. (F-1 nut)
You are going to cause some serious damage to the amp and/or speakers if you don't remove those jumpers.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Thanks for the help guys! The guy I bought the RB-1090 from bought by RB-985MKII so it worked out to be an awesome deal. The 1090 makes a world of difference! More powerful but I was looking for an amp to better control the MW's and the 1090 seems to have been the right choice here!2 Channel Basement Setup:
Rotel RC-1070
Rotel RB-1090
Polk Audio SDA SRS 1.2TL (1991) w/RD0-198 Tweeters. -
That's some serious power there.....hooah!
