People with the onkyo sr806 please step in
Polkie918
Polkie918 Posts: 245
edited November 2009 in Electronics
Couple questions first what does the "pure audio" button do? I havent really ever used it?
also when u are watching a movie what do you set your volume to...I think the highest I have tried is -15db......how much can it go into the + before its too much??
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Post edited by Polkie918 on
    F1nut Posts: 51,787
    You need to make things right with Luke before you continue seeking help here.
  • ViperZ
    ViperZ Posts: 2,046
    The volume level really depends on what Audyssey did to your setup. My speaker levels are lowered for 4-6dB, so I can "crank up" the volume higher than you (on the dial).
    Regarding 'pure audio', all video signals are turned off, front panel is turned off, subwoofer is turned off, all DSP modes are turned off, and your mains are set as large. So basically, full-range stereo.
    On the other hand, 'direct' mode looks the same, but the front panel stays on :).
    There is a huge thread on TX-SR805 (and I am sure on 806 too) on AVS forums. I learned TONS of stuff from there on how to set up my 805 properly.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • comfortablycurt
    comfortablycurt Posts: 6,745
    f1nut wrote: »
    you need to make things right with luke before you continue seeking help here.
    +1000
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • thsmith
    thsmith Posts: 6,082
    yup indeedy
  • george daniel
    george daniel Posts: 12,096
    Polkie918,, did you hear what the man said?
  • comfortablycurt
    I've found that the best way to use the Onkyo 806 is as follows...
    Put in some music with a really loud bass track. I mean really really loud...
    Turn the sub volume ALL THE WAY up. Turn the level trim for each channel ALL THE WAY up. Finally...turn the AVR's volume level ALL THE WAY up. Push play on the CD player.
    If you use this one simple break in method, your 806 will be sure to run for years without a single problem.
  • Pycroft
    Pycroft Posts: 1,961
    i just hope someone who doesnt' know about the other thread and is new at this doesn't read this thread :)
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • inspiredsports
    inspiredsports Posts: 5,502
    It's magic. When you push it it makes your conscience kick in and you take care of your fellow Polkies.
    You've got nerve asking for help around here.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
