has Anyone tried EBAY tonight?
nooshinjohn
I have been trying to get on Ebay for a half hour now and find that I cannot do any searches whatsoever...
anyone else been trying?
same hereSpeakers: SDA-1C (most all the goodies)
I just got right on it
My search isn't working.
I can get on but its f**ked up
same hereI thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
i tried also,go good. something is messed up
thats NO GOOD i mean
Wondering how that effects the items that ended while the system was down.
I got on, but "search" is screwed.
My wife is losing her mind cuz she can't get on Ebay! LOL!Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
Maybe Vladuz got out of jail or found access to a computer.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
it was messed up earlier. I tried when i got home from work and it was back up and running fine again.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
seems to be working againPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I just did a search for polk speakers and got 241 results total, not just in electronics. Its usually over 1000...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
The new and un improved search feature is screwed even when it does workI got on, but "search" is screwed.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
