Adcom 535 and A and B speaker switch
BiotypE
BiotypE Posts: 21
edited November 2009 in 2 Channel Audio
I just picked up an Adcom 535 (this is the first external amp I have ever used) and it made a huge difference in how my speakers sound.
I have a question about the A and B speaker switch. I currently have my RTI A5s hooked up to the A terminals and I am not suing the B speaker terminals. Can I or should I connect both the A and B speaker terminals to my speakers and have both A and B speakers enable on the amp.
Should I do this, would it benefit if I did or could it potentially damage the speakers or the AMP.
I guess I am wondering if I would be doubling the power output to my speakers using both the A and B terminals rather than just the A.
Onkyo TXSR706B
Polk RTIA5s
Acoustech H100 Sub
Kef Egg surround (soon to be Polk surrounds)
Kef IQ6 Center (soon to be Polk center)
Xbox360
PS3
Direct TV HDDVR
  • fbm211
    fbm211 Posts: 1,488
    I dont think it will work.When you switch to A,--B is disabled.B is disabled when you switch to A.At least thats what happened to an amp I use to have like that.Now a QUAD amp will do the trick but it would not be a good idea to hook your speakers up like your thinking of doing.....EVER..
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • BiotypE
    BiotypE Posts: 21
    Thanks for the info. I just wanted to make sure I was getting everything out of it I am supposed to be.
    Onkyo TXSR706B
    Polk RTIA5s
    Acoustech H100 Sub
    Xbox360
    PS3
    Direct TV HDDVR
  • george daniel
    george daniel Posts: 12,096
    That little Adcom,, is a powerhouse of an amp--dual mono-plenty of power for a 60 watt jobbie-congrats and enjoy.:)
  • Systems
    Systems Posts: 14,872
    Selecting A or B only connects or disconnects that particular pair of speakers.If you select A+B then both pairs of speakers will effectively be wired in parallel so the load seen by the amp will lowered.Depending on the impedance of the particular speakers used the impedance may be too low for the amp to drive comfortably.
    Testing
    Testing
    Testing
