how to install caps
whitey240sx
k, so is there anything special i need to do to install a cap? how would i do it? what guage wiring is cool to use and how do i not make it blow up? hgaha
Charlie
Charlie
Post edited by whitey240sx on
see the post below this one titled "mounting a cap"The Artist formerly known as PoweredByDodge
PBD, Did you receive the software yet? Please let me know when you get it.
Chris -
heya chris...
not yet dude but i'll be sure to let u know
The Artist formerly known as PoweredByDodge -
how to install a cap:
take ur cap find out where u want to put it
the closer to the amp the better
you use what ever size wire you have running from your battery(or fuse relay or wherever)
take the wire that runs from the battery to the amp and put it on the positive side of the cap, then take wire the same size and run it from the positive side of the cap to the amp
then screw the screw down over the two wires making sure theres a good connection
take your ground...hook it up to a good peice of metal ground, then hook up your ground to the cap...then the cap to the amp
then take ur radio wire(The one that turns the amp on and off with the radio)
run it to the cap...then to the amp
before you do all that make sure the cap is charged
charging instructions come with it
i think you have it to charge it within 24 hrs of installing it or somewhere around there
-Cody
