Audio Cutting Out
bigaudiofanatic
bigaudiofanatic Posts: 4,415
Now as most of you know I have a new elite unit and love it. I have been pursuing getting a power conditioner and will probably soon have one. I live in a newer house about probably 9 years old. Now when I am listening to much and turn the ceiling fan on "speed high" the audio cuts out for about a second than continues. What could be the cause off this? I know it can not be good.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
  • superjunior
    superjunior Posts: 1,632
    edited November 2009
    the ceiling fan is on the same circuit as the outlet your receiver is plugged into. increasing the amperage on that circuit should fix that.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Squishy Tia
    Squishy Tia Posts: 79
    You'll definitely be wanting a power conditioner if your ceiling fan is on the same circuit, especially if it uses a dimmer switch instead of a toggle switch, as those add a ton of noise to the circuit. The best solution would be to try to see if a different outlet has the same issues. If not, that's the cheapest solution right there.
  • bigaudiofanatic
    Well I do not have a dimmer on my ceiling fan so that saves me some money. Do you think a power conditioner will correct this?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • concealer404
    concealer404 Posts: 7,440
    Should...
  • Face
    Face Posts: 14,340
    Do you have any other outlets in the the room? Are they all on the same breaker?
    I'm not sure if a conditioner would fix your problem, but a UPS would.
  • bigaudiofanatic
    From what I understand all my outlets and lights are all on one line. They go to a secondary fuse box upstairs and than goes downstairs to the main one.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • WilliamM2
    WilliamM2 Posts: 4,829
    Does the power actually shut off? If not, most UPS only kick on when the power is off, so that won't help either.
    Seems like an odd issue. You might want to have the house wiring checked out.
    F1nut Posts: 52,406
    You need a dedicated line for your gear.
  • Face
    Face Posts: 14,340
    WilliamM2 wrote: »
    Both of mine kick on when the voltage drops, it doesn't need to cut out completely.
  • bigaudiofanatic
    WilliamM2 wrote: »
    My unit does not shut off it just acts like the audio input signal was lost and than comes back.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • 20hz
    20hz Posts: 636
    as everone says ..
    you need a dedicated line for the stereo .
    A voltage conditioner wont keep the voltage up to par you would need a iaolation transformer (I got a 6 amp unit weights 40 lbs) it gaurantees to keep 117 volts .
    But I would try and wire the fan to another circuit I dont know if moving the stereo is a option .
    You could try plugging the sub in another outlet .
    But motors do all kinds of havoc , it is known that if you plug a vacuum cleaner in the same outlet as your computer you could kill it .
    They used to sell some "green" thing that plugs into a appliance that was supposed to save electricity .
    I wonder if that would help your fan ?
    I think the fan coming on creats a surge on your stereo .
    Or it may produce a low voltage condition (under 90 volts turns off my panamax).
    Maybe your fan is old and drawing to much power , see if other models draw less ?
  • bigaudiofanatic
    2 problems with that one it is not my house "parents" and I am not planing on living here for the rest of my life so I just need to make it stable for now. Also as I said ALL my outlets are wired together.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Davidb0123
    Davidb0123 Posts: 11
    first or second floor? is ceiling open below?
    treitz3 Posts: 20,367
    Yeah, get that fan off the circuit. Either that or lose the Solid State circuitry that controls the fan. Either way should eliminate the issue.
    I'm taking it that you have one of these.....
    Maybe not the same one but something similar? If so, lose this controller first. Then look elsewhere. ;)
  • bigaudiofanatic
    No my fan speed is controlled by the pull cord. I live on the second floor. What do you mean ceiling open below?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Face
    Face Posts: 14,340
    Don't use the fan or buy a UPS.
    Then you need the fan on a separate circuit. The question about an open ceiling does not apply to you. You could, however, access the fan's circuitry and reroute it through the attic rather easily
  • bigaudiofanatic
    I will have to talk to my Uncle to see how easily that can be done. Would it make any difference to run a new wire from the secondary fuse box directly to my outlet for the stereo?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    Yes. That would be the dedicated line [kinda]. How easy it is and whether it's possible given the current configuration would be another question your uncle would have to diagnose.
  • bigaudiofanatic
    The reason I ask is because I sort of have a front cross space that I can crawl all the way over to the other end of the house and access the fuse box. It would be pretty easy.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    If you can add a true dedicated line to the rig? That would be your best bet. You would eliminate any and all issues at that point, short of power issues leading into the house.
  • bigaudiofanatic
    Well that would be a lot more work. The secondary fuse box would be easier.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited December 2009
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Face
    Face Posts: 14,340
    I would get one rated for at least 1500VA.
    Richard Gray recommended to me Eaton's line of UPS's. I'll check them out if my Belkin Hybrid UPS ever gives out.
  • Serendipity
    Serendipity Posts: 6,975
    The dimmer may just be generating interference on the line.
    I want to make sure - the receiver is NOT going into protect or powering down, right?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • bigaudiofanatic
    Right just please read what I have said their is no NO fan speed controller or dimmer on the fan.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    Just metered my outlet output. Was stable even at excessive volume at 122.8. When the fan or something was plugged in it dropped to 118.9 momentarily.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
