Polk Audio m3 II speakers
njander
njander Posts: 1
edited November 2009 in Vintage Speakers
I have a pair of m3's as my rear surrounds and love them. Problem is they have been mounted in the corners of my living room for more than ten years and I would like to move them but can't remember how they mount. I do know it is a slick mounting system for use in corners. Would appreciate some help.
Post edited by njander on
  • DollarDave
    DollarDave Posts: 2,575
    I have a pair of mounting thingy's out in the garage and can look at them later. I think you have to squeeze the sides of the tabs that slide into two holes. I will verify later today if I can.
    Tony M Posts: 11,575
    The round discs are attached to shafts.
    Use a flathead to gently get the round discs to disengage with the shaft from the cabinet. You must remove both pins(attached to the round discs underneath) to free the M3.
    good luck and use patience.;)
