PSW505 Hook up Questions
Sistum Id
I just got my speakers in last night and set them up. Everything is fine so far. I've steped up from an 6 ot 7 year old Sony AVR with some tiny speaker and small sub. I upgraded to a Onkyo 707 and Polk PSW505, Monitor 70s (Front), Monitor 40s (Rear) and the hugest center I've ever seen CS2.
I have it wired like shown below. It was different from my Sony which was wired like the one shown far below. I haven't tried to bi-wire anything and will try that maybe later once I get my sub figured out.
So my question is this: Which setup is better? Should I leave it like how it is now or go with the LFE? Can I still bi-wire with the wired setup as shown below or not? More complicated the way I have it already?
Below
Far Below
Below
Far Below
My Home Theater Entertainment Center Setup
Fronts: Monitor 70's
Center: CS2
Rears: Monitor 40's
Sub: PSW505
Receiver: Onkyo TX-SR707
TV: Samsung 56A650
Extra: Fat PS3 60GB, Xbox 360 Elite (Jasper), and HTPC
Center: CS2
Rears: Monitor 40's
Sub: PSW505
TV: Samsung 56A650
Post edited by Sistum Id on
I am no expert but I have the same set up as you basically. I would have to say that using the LFE is the way to go but I have not tried it the more complex way. If you try the LFE give us a report on the difference you hear between the two ways. I understand that it is a complete waste of time and money to bi-wire the monitor speakers unless you plan on using several matched high powered and priced external amps. hope this helps.My Setup:
Front- Polk Monitor 70
Center- Polk CS2
Rear - Polk Monitor 70
Subs - 2 Polk PSW505
Receiver - Onkyo TX-SR707
Amp - Emotiva XPA-5
Zone 2 Speakers - Polk M40
CD Player - Emotiva ERC-1
Interconnects - Emo X-Series
& Emo Ultra speaker cables
additional components:
Television - Samsung LN52B750
Gaming Console - Microsoft XBox 360
Media Center - Gaming Computer with Blue Ray Drive -
how do you set the TX-SR707 speakers to "small". I haven't found a large small setting on this receiver but it may be there. anyone know?My Setup:
Center- Polk CS2
Amp - Emotiva XPA-5
Top setup uses the crossover built into the sub like xcapri79 said for older avr's that dont have a sub out. Bottom setup uses the crossover built into the avr I tried both with my setup and prefer the LFE way. Also set the fronts to small look in your manual it should tell you how to set this.TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Correct me if I am wrong...but I don't think the Onkyo has a small or large setting....you will find in the L/R speaker menu.....the term Full range (that is equivalent to LARGE!). Just don't select that! The rest is determined pretty much by the crossover which should be about 80hz for everything.
