Hi! New Member, great site! Could use help
robcrotzer
Hi I'm a new member, long time (10yrs) polk user. I still use my RT35s (front) and RT15's (rear) for surround sound. Question, in my previous house I simply used the "nail hole" on the back of the RT15's to mount them. Now I have a house and a room where I cannot mount them on the side wall. 2 things: is there a cieling or wall bracket for mounting Rt15's? and are they bidirectional if I put them above and behind me?
Thanks! Look forward to exploring the site!
Post edited by robcrotzer on
Many people use the B-Tech BT77 speaker brackets because they clamp onto the speaker so you don't have to drive screws into the cabinets.
http://www.btech-usa.com/bt77.html -
Thanks! I've seen those, though that might be my only option....other brackets as you said I was worried about **** into the cabinets wasn't sure how deep I could go? How bout the 4 holes that are on the back of my rt15's and 35's? were they for a mount in the past or soemthing else?
My guess is that the holes are for the Power Port:
http://www.polkaudio.com/homeaudio/products/recent/rti28/
But why is it removed is the question. -
nope port is intact lol!:) There are 4 additional holes below the power port (recesses I guess would be better description), don't appear to be threaded unless it's deep....
OK, you scared me there for a minute. I honestly don't know then. I'm sure one of the RT owners will chime in shortly though.
This is from the RT15i product page though:
"Mounting Options Wall mounts with integrated key-hole slots. Accepts Omnimount fully articulating bracket" -
yea, gotta get the holes right. can't go around **** random holes.Onkyo 805, RtiA5s, Csi5, Rti6s
I have owned both of those speakers and I do not recall any extra 4 holes in the 15's.
Yeah, that's a good way to catch a disease.
Rob: maybe you can post a picture of the back of the speakers to help up get an idea. -
will do tonight when I get home, thanks!
+1 for the Btech 77. Nice mounts and will allow you to aim down to the listening position.Shoot the jumper.....................BALLIN.............!!!!!
