I need a little help...
edbert
edbert Posts: 1,041
edited November 2009 in The Clubhouse
So I received an iPod as a karma a while ago(Thanks Pauly!). I finally got around to getting a new battery and firewire cable so that I could use it in the house and at work(I had a car charger and FM transmitter for on the way to work). Anyway, in the process of replacing the battery I managed to rip off the connector for the headphone/molex jack. While I could attempt to fix it, I would probably only destroy it. I was just curious if there was anyone on here that has some mad soldering skills that would like to try their hand at it. If it doesn't work it isn't any big deal since I wasn't using the headphone jack before. I can send the cable out with a postage paid envelope so it won't cost you anything but a little time. I'll see if I can't find something to throw in there to thank you for your time.
Thanks!
Eric
(see picture for the part that needs to be reattached)
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
