Frozen Driver's
Hamatym
Hamatym Posts: 269
edited November 2009 in Vintage Speakers
I know I saw postings on this before, but can't find them in my search. If a Driver freeze's up, can it be unfrozen somehow? or is it junk from there?
Just curious if there is a trick with magnets or something that can bring them back to life....Any response is appreciated!
Thanks All
Post edited by Hamatym on
  • kawizx9r
    kawizx9r Posts: 5,150
    Far as I read, no one's been able to fix a frozen driver although I can look for a thread that better helps to prevent this. It focuses on where the magnet/plate shifts.
    Edit: Here you go, enjoy! http://www.polkaudio.com/forums/showthread.php?t=87460&highlight=magnet+shift
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • bluecomet
    bluecomet Posts: 1,118
    Sorry but it's time to get a new driver. Depending on the model, Polk will probably have the driver. Tell them you are a member to get a discount. What driver do you need?
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Hamatym
    Hamatym Posts: 269
    What up Blue Comet! I need (3) MW6503 driver's for my Monitor 10's that match my other monitor's...I just picked up set of Mint 10B's from a guy in Columbus, but it must be an early version than mine as it's slightly different. It also uses MW6501's, which I am sure are just fine but I want to keep everything stock.
    I did take one frozen driver apart really easy by hand, but have no idea how realign it back....It was worth this post to see if it's fixable but I just need to find replacements. PM me if you can help
  • JotGloky73
    JotGloky73 Posts: 10
    I cant find any drivers for the integrated sound on my old machine with Windows 7.
    Its a C-Media CM8738 Integrated but I cannot find any drivers.
    Anyone know where to get them?
    F1nut Posts: 52,000
    Not here, that's for sure.
    Toolfan66 Posts: 18,186
    I have a frozen driver I have played with many times. I have been thinking of a way to make a tool to realign them, they had to go together in the first place so there has to be a way of making something to realign them.
  • dorokusai
    dorokusai Posts: 25,576
    Frozen = Trash.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Lasareath,
    You have a PM
    TOOLFORLIFE
    you might want to search for a site that sells replacement cones (a lot of times called recone) they tell you how to line up the voice coil/pole piece and the cone which would be pretty similar. You would have to remove the the dust cap and get some surround/dust cap adhesive
    Good luck,
    Ted
  • Driver_King
    Driver_King Posts: 266
    I tried fixing my three frozen drivers once before. That didn't work so well.:o Maybe I just couldn't figure out how to get the jig together properly but I think it's more difficult than just making a cheap jig and moving the magnet back into place. I think you would need to go to a professional that has equipment that could align the magnets. That would likely cost more than just getting replacements though. If you do try the DIY route, let us know how it worked for you.;)
    Home Theater:
    Onkyo TX-SR805
    Behringer EP2500 for SDA's
    Polk SDA II fronts
    Polk Monitor 5Jr. surrounds
    Polk Monitor 4 back surrounds
    DIY A7-900 and DIY A3-300
  • dudeinaroom
    How does your surround set up sound? I have SDA2As and A Mon, & center. I want monitor 10s for the rears.
  • Driver_King
    I love how seemless everything is. It is hard not to get lost in a movie or just keep listening to music. The subwoofers also complement the system very well. Explosions are unreal. It's as close as you ever probably would want to get to a real explosion.:eek::D:cool: If possible, make sure all of the tweeters in your speakers are the same. My SDA's and Monitor 5Jr.'s have the same tweeters.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
