12/2 or 12/4??
hglass
I'm going to install my rear surround speakers. The speakers are to be bi-wired. Should I use a 12/4 cable or run 2 sets of wires 12/2 and join the cables at the amp.? Will I get better sound from the two sets of 12/2 or am I wasting money?
You'll see mixed feelings on this topic.
Some say the shielding of all 4 wires in a single sheathing is not enough protection so you should use separate wires for your high-pass and low-pass signals. But this is more for a bi-amping situation.
Since you are going to bi-wire, I think you should be fine. I use 12/4 wire with my fronts and center (my surrounds are not bi-wire/bi-amp capable), but I did run 12/4 wire to them in the event I ever move to different surrounds. -
12/4 IMHO.
Simply put: I think it work's
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
