Hey PoweredByDodge
Jstas
I goobered up those terminal cups with blue ATV gasket maker on the DX9's in the boxes I grabbed from you. It made a hell of a difference! They actually hit pretty freaking had on 16 watts of tube amp power! Bass is sharp and seems cut off. I don't think the boxes are big enough. So I think I'm gonna go with the ports. 2 inch by 5 inch ports should give enough length to vent them properly and some polyfil in the box, should work out ok. I'll let you know how well it goes but the terminal cups aren't leaking or moving and there is a night and day difference. No more distortion either.
Expert Moron Extraordinaire
Post edited by Jstas on
hey also -- weather stripping behind the speaker flange (that way u can mount, unmount it at will)... then u're guaranteed no leaks there....
dude i'm tellin ya those suckers POUND... with 4 of the DB 6x9's and 70-ish watts on each in a big iso box people thought i had subwoofers.The Artist formerly known as PoweredByDodge
