Powering up 250W Amps
Rennrig
Rennrig Posts: 16
Hi Club Polk
I am wondering the safest way to plug in my B & K 200.1 250W Mono amps. Are these two big to plug into a unit like the APC H10? My dealer suggest always plugging amps into the wall. This present sort of a location problem. I am thinking of taking one outlet box and hard wiring a interface for an outlet box that I can run (like a cable) to the amps.
Am I over thinking this issue, and should just plug the amps into the same unit everything else in the rack is going into?
Thanks,
Rennrig
  • Face
    Face Posts: 14,340
    edited November 2009
    Does the APC have "high current" outlets? If so, it may not limit the amps as much.
  • Rennrig
    Rennrig Posts: 16
    Hi
    It has two "high current" filter outlets. It is rated for 1000 watts continuous, and much higher for surges. Is the issue with conditioners "limiting" the amps? If so, what does this imply?
  • danz1906
    danz1906 Posts: 5,144
    Rennrig wrote: »
    Hi Club Polk
    Thanks,
    Rennrig
    Welcome to the Club!
    Very nice amps, I used to have the same Amps. I plugged them into
    my Richard Gray power cond with no problems. Although into the wall
    would be better.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Face
    Face Posts: 14,340
    My UPS/Conditioner is rated for 1500VA continuous and I feel that it limits the dynamics of the few amps I've tried through it. Not terribly, but noticeable. I use a Richard Gray 400 Pro in my other rig and feel it's as close to plugging the amps into wall as you can get. When I get some extra funds I'm going to also purchase one for my HT rig's amps.
    Give the conditioner a try, it may sound fine to you. If it sounds flat or lacking, you know what you need to do. :)
  • dcmartinpc
    dcmartinpc Posts: 844
    I run a Tripp Lite LCR2400 and love it! It seems to have the reserves I need to make my Epik Sentinel sub shake the house off of its foundation and keep the Parasound 2205 happy in very dynamic movie scenes....
    It is no fluff clean power and has 2 banks of outlets, one for high current, and the other for regular devices. It works well for me.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • fbm211
    fbm211 Posts: 1,488
    I also have the LCR2400. I have my 300+ watt Adcoms plugged into it with no problems.In fact they sound better than when I had them plugged into the wall.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Rennrig
    Rennrig Posts: 16
    Thanks Folks, this is great information and I think the bottom line is to try it and see how it works out, worse case I will plug them into the wall.
    I have not heard of any safety issues regarding damaging equipment using one of these aforementioned devices??
  • 20hz
    20hz Posts: 636
    I would try a panamax m5100 it has a timed amp plugs triggered off my receiver , plus panamax stands behind anything plugged into the unit .
    Also my last one started to wear the releys out and panamax sent me a BRAND new one for $25 !
    Great American company with a great product !
  • danz1906
    Rennrig wrote: »
    How did it work out for you???
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    20hz wrote: »
    Agreed, Panamax is a good company!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • lumpy
    lumpy Posts: 113
    edited December 2009
    I have a couple of the panamax units. Another added benefit is that you can run a 12v trigger from your receiver to the panamax as a method of turning on and off the amps when you shut down the receiver.
    I suspect that other companies conditioners will do this too.
    pop
    media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
    living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
