Repair piano black finish on MicroPRO woofer
alexksj
alexksj Posts: 5
edited November 2009 in Speakers
Hi,
I just got a Polk MicroPRO 3000 subwoofer. I got a really good deal because it has a deep gash in the piano black finish at one of the corners. Doesn't seem to affect performance.
What's your recommendation how to reasonably patch this? I don't want to refinish the whole thing, just the affected area. It shouldn't be visible "across the room", but it's ok if it is noticeable on close inspection.
Is it ok to use Bondo on the exposed MDF? What paint should I use?
Thanks!
Alex
Post edited by alexksj on
  • Montoya
    Montoya Posts: 506
    tamiya makes a really good high gloss laquer paint. Not sure about the bondo though.
    alexksj wrote: »
    Hi,
    Thanks!
    Alex
    F1nut Posts: 51,692
    A burn in repair is your best bet.
  • rallyshark
    rallyshark Posts: 417
    What is a burn in repair? How does that work?
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • mmadden28
    mmadden28 Posts: 4,283
    I know there is an LSi black lacquer repair thread around here somewhere...looking
    ____________________
    Pool: Atrium 60's/45's
  • Ricardo
    Ricardo Posts: 10,636
    This is a good process to follow (Starting on post # 11):
    How to Repair Piano Black Finish
    SOPA
  • Jstas
    Jstas Posts: 14,977
    I'm not sure what the burn in approach is either but, I have repaired piano black finishes in the past with a bit of acrylic resin and a fair amount of sanding and polishing. Provided the gash is still black and isn't showing the structural material beneath it.
    The acrylic acts like a clear coat would and lets the black color come through but fills in the gash and makes it look smooth and shiny, like the rest of the finish. It's noticeable upon closer inspection but hidden in the corner of the room, it won't draw your eye to it anymore. The nice thing about it is that all of the stuff you need can be picked up at Home Depot or Pep Boys for less than $35.
    But F1nut fixes stuff like that for a living so I'd trust him over me.
    Expert Moron Extraordinaire
  • mmadden28
    Ricardo wrote: »
    I couldn't find the discussion I was looking for , but that link has the exact same repair so the other discussion probably also linked to that repair.
  • NJPOLKER
    NJPOLKER Posts: 3,474
    Ricardo wrote: »
    I stopped at post #4 and bet I'm not the only one.
  • mmadden28
    NJPOLKER wrote: »
    hehehe ;)
  • Bernal
    Bernal Posts: 991
    Very interesting
  • alexksj
    alexksj Posts: 5
    Thanks a lot, the link was exactly what I was looking for. This seems to be within my abilities. BTW, this is how my woofer looks like right now. Not perfect, but paying $300 for a new $1500 speaker with ding, I'm not going to argue...
    F1nut Posts: 51,692
    One way or the other, doing it right takes time, money and skill. If you really want it done right, take it to a pro. Otherwise, good luck and have fun.
    nooshinjohn Posts: 25,887
    What I did was fill the damaged areas on 1 of my LSi15's and then took it to a body shop and had them shoot it with automotive paint. Then it was color-sanded and rubbed out. According to Polk customer service, they are painted and finished in much the same way at the factory.
