The Ultimate Speaker System
MxStYlEpOlKmAn
MxStYlEpOlKmAn Posts: 2,116
Those of you who have not heard Def Tech speakers, outta hear this setup in 7.1. I heard them today, and I was totally blown away. Here they are....
Mains:
BP3000TL Specifications: Dimensions: 9"W x 19"D x 55"H Response: 13 Hz-30 kHz. Efficiency: 92 dB. Drivers: 4-6.5" cast-basket, bass/midrange drivers, 2-1" pure aluminum dome tweeters in D'Appolito arrays, cast-basket 18" sub w/1000-watt RMS Infinite Power Source amp. Connections: tri-wirable with separate five-way gold binding posts and optional separate low level full range and LFE inputs. Rec. Amp.: 30-600 watts. Nominal Imp.: 4-8 ohms. Auto On/Off: Signal sensing. Finish: piano gloss black. Weight: 153 lbs. Retail: Black $2250.00 ea.
Center:
C/L/R 3000 Specifications: Dimensions: 25"W x 8 5/16"H x 16"D. Response: 19-30 kHz. Nominal Imp.: 4-8 ohms. Rec. amp: 20-400 watts. Built-in sub amp: 150 watts RMS. Drivers: 10" sub, 2 cast-basket 6.5" bass/midranges, 1" pure aluminum dome tweeter. Auto On/Off: Signal sensing. Finish: piano gloss black or golden cherry. Tri-wireable. Retail: $999 ea.
Surrounds:
BPVX/P Specifications: Dimensions: 22 1/8"H x 11 3/8"W x 7 3/4"D. Response: 23-30 kHz. Drivers: 2 cast-basket 6.5" bass/mid, 2 cast-basket 6.5" subs, 2-1" pure aluminum domes. Rec. Amp: 20-400 watts.Built-in Subwoofer Power Amplifier: 125 watts RMS. Nominal Imp.: 4-8 ohms. Auto On/Off: Signal sensing. Finish: Gloss black or matte white. Retail: White $699 ea., Black - $749 ea
The bass is unreal in this system, soundstage, imaging, treble, midrange, everything is top notch. I have never heard a system that sounded so good. The center channel handled everything and was just COMPLETELY awesome. This of course is my opinion! But I like to share my opinion, all their speakers are finished in Piano Gloss Black, but have a wrap around grill, its all taste, but I think these speakers absolutely kick ****$.
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
Post edited by RyanC_Masimo on
