Poping Speakers...
ChevyMan4x4
As you all know I am running 2 12's on a Memphis amp Volfenhags. Well they "Pop" whenever you are going down the road and it hits a lower note on the "bass" scale... Well not so much as a pop than a Click.. either way is it hurting my speakers?? I mean there not blow but it kinda get's on my nerves even though the sub are ear bleeding loud... I am just worried about it causing damage to the woofers. I don't think they are blow because they only "pop" on the really low bass intense note but are fine on the punchy bass.. Figured that someone here would know what is causing this... O by the way they did not make this sould when they where in the ported box I had built for them... Right now there in a dual 1.5 cube cambered power wedge box.. Like I said I have to clue what could be causing the poping sound.:D
Sir Daniel X. Boom - the GNX slayer
Post edited by ChevyMan4x4 on
my old momos made a popping sound
i took them out of the box and the spider was cracked on both of them and i had to send them back
-Cody -
my dx10 made a sick popping / clicking sound just before/as/after it went to hell.
its not a good thing... dont play them so loud .. honestly that amp is a LOT of power... less u wanna blow em, watch out for em.The Artist formerly known as PoweredByDodge -
what other speakers are u running? you might need some diodes
diodes for speakers?
a diode on an AC line will cut half of its output out.
speaker fuses i've seen, speaker diodes... no.The Artist formerly known as PoweredByDodge
