Do i have enough power ???
edited November 2009 in Speakers
I have a harmon/kardon AVR120 which is rated at 50 watts per channel for 2.1 channels and 40 watts per channel for 5.1, if i have two Monitor 60's up front, would the amount of power i have lead to clipping or is it enough ?
Thanks,
Dan
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD :D
Playstation 3
Post edited by Dan2036 on
Welcome!
    Dan2036 wrote: »
    Thanks,
    Dan
    Depends on how loud you like to listen to for movies or music, the size of your listening room, how far away your listening position is, and the dynamics of the movies or music.
    Power can be quickly used up depending on all these factors which may lead to clipping.
    It is a small room, but i like to listen loud, it being a small room the listening position is fairly close, is it just volume power effects or quality overall ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    Dan2036 wrote: »
    The Monitor 60 is fairly efficient at 90dB w/ 1 Watt input.
    But again, if you like to listen loud then I would say that they would benefit in sound quality and security if you considered adding an external amp to your fronts (assuming that your AVR has pre-outs for connecting in an external amp).
    i'll have to think about that, unfortunately no pre-outs on the AVR so i may have to consider a more powerful receiver. Thanks for the help
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    Dan2036 wrote: »
    I am only erring on the side of caution, cuz in my younger years, in my quest for volume I would clip and blow alot of tweeters in my speakers with a 40 watt Stereo Receiver.
    At moderate volumes, I would say you would be safe/ok.
    In terms of db what would you consider loud ? Cause it may only seem loud to me because it's such a small room
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    Dan2036 wrote: »
    Sabbath loud!! :D
    Ha, k Gotchya
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    I would suggest a new reciever with more power and pre outs for an amp. If a reciever says it puts out 50 watts per channel then most likely cut that in half. They always lie and overrate the readings to sell them. More power is always better no matter what. Once I had 2 emotiva xpa-1's which are the 1000 monoblock amps and I must say I never heard my speakers sound so good. They sounded like they had 12" subs in them. I recently sold them and am now using an xpa-3 and a upa-2 for surrounds. seperate amps is the way to go. the amps in receivers are junk and over rated and under powerd. There is no way a 25 lb reciever can put out the power it claims. They use cheap transformers and internal parts.
    Dan2036 wrote: »
    Thanks,
    Dan
    Welcome to the Club!
    You should be ok with the H/k, Harmon rates its AVRs conservative.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    selkec wrote: »
    Harman Kardon is one of the few manufacturers that provide honest power ratings....they actually underrate their amps. If HK claims his receiver claims to push 40 watts, thats 40 watts RMS with all channels driven. 50 watts from an HK is equivalent to somewhere around 100+ watts from another manufacturer. HK receivers and amps are HEAVY. Despite how they rate their products, they make beefy stuff
    Now 40 watts from even an HK amp isn't a whole lot, but the Monitor 60's very efficient and easy to drive. Plenty of people run them on receivers with integrated amps and are doing fine. I was driving a set of TSi300's (very close to the Monitor 60s) with my Onkyo 706, and was able to push them louder than I care to listen to for prolonged periods of time without distortion. With a speaker like the Monitor 60, the adding an additional would provide minimal benefits for the money, especially when you consider that a single mono-block amp will run more than the cost of a pair of Monitor 60's right now.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    IMO you can never have too much power. You just don't have to use all that power. But it is there if you need it.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    thuffman03 wrote: »
    True...to a point. Having more power gives you additional head-room which is especially important for movies, where there can be huge spikes in power requirements in scenes with a lot going on in the soundtrack. You also benefit from the increased dynamic range when you aren't constanty running an amp close to its limits. Honestly, I think the increased dynamic range and the overall 'fuller' sound across all volume levels is a much bigger improvement than the additional headroom and SPL.
    While you can never have too much power, when you consider the price you pay for additional watts, you very quickly hit a point of diminishing returns unless you're running very high end, or very inefficient speakers. For a speaker like the monitor 60, which is very efficient, and has fallen very drastically in price, it would be most cost effective to upgrade the speakers than the amp.
    My System Showcase!
    Media Room
    Living-room
    Headphones
    I ran monitor 60s off of an H/K AVR-140 (45wpc) for a long time, I have also run Monitor 40s, as well as Monitor 70s off this same receiver. I consistantly listen at around -10db (of +10db max) for a few hours at a time, with little in the way of heat build up (receiver is not vented very well either) and with no audible clipping. This is with a variety of media formats as well. Additionaly, I watch movies at about -17db.
    The rooms is small (13'x11'x7') as well
Welcome!
Welcome!
